Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > South Central Regional States
South Central Regional States Local discussions for those on the South Central US. (Arkansas, Louisiana, Oklahoma and Texas)
Old March 2nd, 2017, 21:08   #181
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Originally Posted by skiaspeblu View Post
how much and how I can send it the one ecu you will repair
I reply on your PM.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old March 14th, 2017, 13:10   #182
1.8terrible
TDI(s): 03 1.8t
Wanted to come and say thank you as well to Marin. He helped me out of a very sticky situation with my Jetta.
Long story short, when I bought my car, I was unaware that the used car dealer I bought the car from disabled my CEL. I was unable to pass inspection or get registration for over a year after the registration/inspection that came with the car expired. After taking it to the dealership I was quickly aware that having a vw dealership fix the issues was not an option. Being an unemployed recent graduate, I just don't have that kind of money.
Luckily, I found Marin. He understood my situation and need to get the car passing inspection for job hunting. After dropping off my car Marin was able to repair my damaged instrument cluster (VW wanted to program in a brand new cluster), and get my car inspection ready. Since I left my insurance with him he was even able to take it to a nearby inspection shop, so when I picked up the car I just had to take it for registration. He did all of this for a fraction of what the dealership quoted me.
I cant thank you enough, I went from not being able to really drive the car for over a year, to having it in full working order in a day. If anyone is hesitant about taking your car to Marin, don't be. I don't like just anyone working on my car, but this guy really knows what he is doing and will take care of your vehicle. Can not wait to use him again.
1.8terrible is offline   Reply With Quote
Old March 16th, 2017, 18:49   #183
voilsb
I forgot to write a review...
A few months ago I took my car to Marin for a timing belt job and some other mods, and he did an excellent job. He also found (and showed me) some damage the dealership had done during a warranty hpfp replacement. Finally, he had the integrity to refuse to do some work that he felt like the risk outweighed the benefits due to what appeared to be sub-par materials.
Excellent, intelligent, professional mechanic who is willing to go the extra mile to explain and demonstrate what's going on with the work he performs with the integrity to ensure his work stands up to his name.
Sent from my SM-T700 using Tapatalk
voilsb is offline   Reply With Quote
Old March 21st, 2017, 10:06   #184
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Marin,
I can't thank you enough for the cluster and ECU work! The engine started on the first key cycle.
All,
I was working on swapping my DSG for a manual, 5sp. Everything was a bolt-in solution, but I wanted the swap to be as original and as trouble free as possible. Consequently, my biggest concern was the ECU, Cluster, Immobilizer, and wiring.
I contacted Marin about recoding my cluster from a DSG to manual, and recoding the donor ECU VIN to match mine.
Everything worked without a problem!
Thanks again!
Tony
Diesel fleet: 2015 Jetta TDI SE DSG; 2006 Jetta, TDI, DSG-5sp Conversion; 2006 DC Cummins, CC/LB/DRW; 1996 Passat TDI, 5sp, Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old June 25th, 2017, 07:25   #185
DougZ
Default Avoid him
Read his posts, carefully. Listen to him. Nothing is ever Marin's fault.
I have seen him three times. The last was at G Tech Imports, 13535 Floyd Circle, Dallas, TX 75243. He refused to honor his warranty.
On April 17, 2017 I had my car towed to Marin because the ignition key would not turn and I could not start the car. Marin replaced the ignition cylinder housing. I paid $550.00. His invoice simply states, “All PARTS has 10 months or 10000 mile warranty. All LABOR has 6 months or 6000 miles warranty. No warranty applies if customer provides the parts.”
On June 9, 2017, 53-days later, the ignition key would not turn, again. And this time, the steering wheel was locked. I texted Marin. He quickly replied he was too far away to help and anyway, the problem was entirely my fault: I parked the car improperly; I got out of the car incorrectly; I was not jiggling the steering wheel the right way. He sent me links to a couple YouTube videos describing his point of view. The advice was not useful.
About an hour later, a tow truck arrived and took me and my broken car to the local VW dealership.
After the car was fixed I sent him a copy of the invoice. Marin exclaimed, “They replaced the same part I replaced!” He refused to honor his warranty.
Marin is responsible for nothing.
DougZ is offline   Reply With Quote
Old July 24th, 2017, 06:55   #186
jetta ,97
jetta ,97's Avatar
For all other users who will read this post I want to say my side story:
This guy what me warranty someone else job, He called me after working hours on Friday and I spend 1.5 hours on the phone between text messages and phone conversation to try to help him. After 1.5 hours I told him I will come on Saturday where car is to see what is going on,and if I can not do anything over there , I will tow to my shop and stay by my warranty .
All of the sudden , He decide to take car to dealer, and after that he want me to stay by my warranty after Dealer did job. He wants me to pay Dealer charge. I told him that does not work like that , you have to bring car back to me , that I will provide job and chnage faulty parts and give a warranty.
I told this guy, If is the same part fail , I will warranty it , do not pay to dealer , I will tow car to my shop and fix it under warranty.If you want to take second a pinion, you can do that , let them diagnose but do not pay for replacement since you have warranty.
I do provide warranty for all costumes , but I do not provide warranty if customer goes somewhere else and someone else do the job, I am not extended warranty company , even if you have extended warranty company they have to approve job first, not just go to any shop, do the job and give them invoice ,
" here I want you to pay me this you guys said you will warranty stuff for X amount of the months and miles".
This is what this guy did , he went to other repair shop , did job, send me invoice and told me I need to pay that , this way he wants me provide my warranty. This does not work anywhere , not just with me.
HEX+CAN
Old September 2nd, 2017, 17:16   #187
Renee
TDI(s): 2004 Jetta
looks like you are the go to guy for issues, 2 ECUs for one car, obtaining pins, and great work. to bad I am in CA. I will emails you my questions/issues.
Renée
Renee is offline   Reply With Quote
Old September 6th, 2017, 21:57   #188
jetta ,97
jetta ,97's Avatar
Renée
I got your email.
HEX+CAN
Old October 18th, 2017, 18:00   #189
Poolejames
TDI(s): 2002 vw golf
https://log.malonetuning.com/chart/3...hX8kXBsBAAA%3D
i am having issues with my car. This log is with my rod adjusted longer than it should be. I will properly adjust it tomorrow and show new long. new maf, map, turbo, n75, n18 and n239 are deleted.
Poolejames is offline   Reply With Quote
Old October 19th, 2017, 14:57   #190
jetta ,97
jetta ,97's Avatar
If you are in DFW area I can take a look car and see what is going on.
Otherwise,best will be to make a new thread in specific section for your car.
Marin
HEX+CAN
Old December 14th, 2017, 10:25   #191
Strider17
TDI(s): MK4 and MK5
Jetta_97 has helped me with my 2009 2.5L gas to 2.0 CR TDI swap on my 2009 jetta wagon
he knew exactly what he was doing and got it done fast and right the first time around....flawless!!
he was able to take my full FIS cluster from the 2.5L, take my donor half fis cluster from the 2.0 CR TDI and take all the immobilizer and programming and combine it into a FULL FIS diesel cluster i gave him. Along with programming the keys/ECU.
all i did was plugged it in and worked.
update: few months later!
everything still works exactly how it should. no codes and no problems!
I highly recommend his work to everyone and i will definitely be a returning customer of his with my other diesel swaps
Strider17 is offline   Reply With Quote
Old April 2nd, 2018, 08:39   #192
jetta ,97
jetta ,97's Avatar
Thank you .
I can wait for that Passat TDI swap you are doing at moment.
HEX+CAN
Old June 16th, 2018, 20:48   #193
dieselgti
Fuel Economy: Low 30's :(
Just sent you an email about a cluster swap for a mk5 TDI...
Might want a mk6 cluster swap for another VW at some point too
Brandon
'06 GTI 2.0T FSI
dieselgti is offline   Reply With Quote
Old June 28th, 2018, 03:24   #194
zleem60
Jetta,97
After reading all the post here. I am hoping you can help me with my car problem.
2006 Jetta Tdi. I am having an issue with car starting and stopping within 2 seconds. Replaced Relay 460 and still same problem.
The instrument cluster does not move, no lights, all gauges do not move. The center screen that display door open, that still works. Got P1650 error on Vagcom. Is my cluster toast?
How much for repair? I am Running out of ideas.
Mike
Sent from my SM-G955U using Tapatalk
zleem60 is offline   Reply With Quote
Old June 28th, 2018, 07:21   #195
jetta ,97
jetta ,97's Avatar
Check your Private message , I sent you one.
It is possible that cluster is bad .
Originally Posted by zleem60 View Post
Jetta,97
Mike
HEX+CAN
Page generated in 0.16080 seconds with 11 queries
[Output: 136.40 Kb. compressed to 115.23 Kb. by saving 21.17 Kb. (15.52%)]
