yahjnby
- Joined
- Oct 14, 2017
- Location
- Mill Valley Ca
- TDI
- 1998 New Beetle TDI ALH 1.9 Part owner Sencond New Beetle 98 TDI ALH and a 2002 TDI New Beetle
First time rebuild of old project car. 98 NB ALH.
New ring gaps are measuring slightly larger than new ring spec in my Bently manual. Manual says max new ring gap for top two rings is 0.0157 in. Mine run bigger. 0.016 to 0.020 in.
The thing is, the manual also says max wear limit is 0.039
Seems like I'm well within a reasonable tollerance.
Plus boxes and packaging for rings is now all oily and written on.
So, I'm strongly inclined to just drop them in as is.
Question?
Is this negligible, small, medium or "My God man Noooo!"
Also, bore diameters are still within wear limits for standard.
Thank you
PS Oil ring gaps are within spec for new.
Question?
Thank you
