gforce1108
- Joined
- Aug 2, 2006
- Location
- Newburgh, NY
- TDI
- 04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
*** UPDATE - 4 years and 60 thousand miles later I got the car back to fix the clutch ***
I've been working on a coworkers 98 Beetle TDI - just finished up a ton of work and it's running great but the clutch hasn't been right since he bought it. No slipping - but released pretty much at the floor. I bled out the brakes and the clutch cylinders (super blue racing fluid) and it got a bit better. Didn't have to mash it into the carpet, but was still very low.
As I was driving it back to him, I noticed that if I pumped the clutch about 10 times it released at the normal height. After a while, it would go back to releasing at the floor (pedal movement has always felt normal).
I'm guessing that the clutch master cylinder has a bad seal, but I guess it could be the slave cylinder too. Any way to isolate one from the other, or should I plan on replacing both?
