Hi, thanks for the question, the best way to help is if you let us know the bulb types / housing color it is behind and what it is being used as so for example:
1156 bulb
behind a red housing
used as brake/tails
We are able to help with what you might need much better this way.
Thank you
HI,
I'm a different customer but I have a question I need help with....
FWIW - I bought your brake lights for my 2003 Jetta and perhaps there was a misunderstanding...
1) The lights I received did fit my "brake lights" BUT they only fit my brake housing "running lights" (as in when turn the lights on, these are the lights in the brake housing that always illuminate....a "parking" light of sorts.
What I WANTED was the lights that actually act as a running light AND then glow when the brakes are applied....An ACTUAL BRAKE light that glows when the brakes are APPLIED (they ARE a dual filliment bulb....parking/ running lights when just driving with the lights on THEN glow brighter when the brakes are applied).
I do LIKE the brighter brake "running" lights and will keep them (easier to see me in foggy conditions AND maybe the extra brightness will keep tailgaters off my rear when I am going slow (i.e. the speed limit !) on unfamiliar 2 lane country roads I often travel as a delivery driver them BUT I want the actual bulbs than glow when the brakes are applied (it is in a RED housing).
Can you please send me a part number or link to what I REALLY wanted ?
Andrew
PS - I did install the brighter reverse lights and all I can say is WOW !!!
REALLY GOOD and helpful for use with my dark tinted windows when
backing..
I'm installing your side marker LEDs later today....
