Joseph Paniagua
I recently bought a 2000 vw Beetle tdi with 192K miles. Was running perfect but was due a timing belt change. Took to shop where they replaced the timing belt, rollers, waterpump and serpentine belt. Immediately drove it 100 miles at 65-70 mph, ran perfect and suddenly shut off and died. Upon inspection, timing belt was secure but the lifters were blown and the valves bent. Shop says they did not do anything to loosen the camshaft pully, but upon doing a valve job the machine shop noticed the cam pulley seemed loose and showed the pulley had done some dmg to the cam where it fit into it. There appears to be a small rectanguelar hole (such as where a woodriff? key fits in, but there is no key and the only thing holding pulley to cam is the bolt. Shd there be a "woodriff" key or if not what is the small rectangular hole in the cam for? What could have possibly loosened the pulley? Any insight will help. Shd I replace the pulley or not?
Thanks all...
Thanks all...
