There will always be manufacturing anomalies...always... with batteries, and with automobiles.
So far, there don't seem to be excessive new Passat failures of either, OEM VW batteries nor VW electrical systems. When they fail prematurely, it's a royal pain for both car owner and tech to find the cause, in addition to the inconvenience.
Yes...the deathstar sounds are initially alarming, then annoying, then, sadly, you'll learn to stop listening to your car, as it will be such an irritant. Unfortunately, if you get to that point, you'll miss critical sounds that an enthusiast NEEDS to hear, to prevent on-the-road breakdowns. Which sounds are good, which are bad? I'm still guessing...
...Brought to you by a "drive some, worry enough" enthusiast...
