CharlieT
Looking for some sage advice.
I have a bare BHW block here that picked up and I was planning to use, however it appears the main caps are mismatched to the block (they came loose in a box, not mounted to block, which made me suspicious). #1 lines up nicely, but then they get progressively more misaligned to #5. It looks like #5 is offset by about 0.010".
Are there any clever tricks I can use to make this useable ? If I get it line bored, I will need main bearings with oversized OD, which don't appear to exist. I have only found "0.25mm and 0.5mm oversized" mains with smaller ID, to allow crank regrind.
any tricks ? or is it really useless ?
thx
thx
