gioTDI
So the CEL cam on with 2 codes - Camshaft position sensor and Intake Manifold Flat -Intermittent signal or something like that
So i read some post of what people did and most of them had to replace it
But i can't find the part number for this thing so i need HELP with this
Is the Intake manifold flap motor same as EGR valve or no? (my understanding that it is not, but i want to check)
So on Sunday ill try to clean and inspect it to see if the teeth are fine or have been broken
And as well for the Camshaft Position sensor, what part # is it or can it be fixed without replacing it
Thank you in advance for your help
