Ok so u time it by the vcds . Thanks for the help . Yeah cam and crank I know need to be on point just wasn't sure if injection pump needed to be timed like that also
Why would you do that? There is a lot of crap on ebay that might work for the first 5-10k miles then fail on your because of the low quality. For all the work you will be doing to rebuild you should verify the source and quality of what you are purchasing.Thanks for the info . I'm going to read up on all the links in trying to take in all the info I can
I'm not getting my head rebilt it was not salvagable so I'm gunna pick up a used one off of eBay . Slap it on and hope for the best . I already checked the deck and it's ok . But any reputable machine shop should b able to rebuild a head .
I'm sure there's some people on here who could recommend someone who spelazies on these heads
Not as of right now I was looking for timing marks so when I put the head on and time the motor everything would b ok. it has about 140k on it I'm gunna hope it works properly and doesn't leakBack to the original question, are you looking for info to rebuild the pump?
When they sit up like that for so long it can cause the seals to start to leak. Should be easy enough for you to fix it with a kit.Not as of right now I was looking for timing marks so when I put the head on and time the motor everything would b ok. it has about 140k on it I'm gunna hope it works properly and doesn't leak
It was my fathers car timing belt ripped off a few teeth . Head is demolished car has been sitting for about a year and a half . I'm gunna put a head on and hope it's gunna start.
I was gunna 5 speed swap it but I decided if I'm gunna put a lot of work into something I would rather have a wagon to put work into .
Sounds like a plan.
The Pump, Cam and Crank are all aligned for mechanical timing on the diesel. It's a different procedure than a gas motor. MKIV or A4 is just a platform.
All forum search engines seem a bit lacking, even in Advanced or Boolean mode.
Try this user contributed search, use the input box near the center left of the page.
