Hi, I've heard that replacing the transmission fluid on my car is more than just draining & filling it. Can anyone tell me more? Can anyone point me to a website that will tell me more?
There is a write-up in the How-To section of the TDI 101, but that is for the four speed automatic(01M). It might give you some general idea.
I have the five speed auto in my 05 Golf(09A), but I'm not certain if you have the same in your Passat.
Yes, you do need a vag-com so that you can check the temp at just the right temperature. Because the fluid expands and contracts with temperature, if the fluid is too cold, you'll overfill. If it's too hot, you'll underfill. Here's some more information on the process with some good pics: http://www.taligentx.com/passat/maintenance/atfchange/
Here's a direct picture looking UP (yes I said "up") into the filler hole (the filler hole is on the bottom of the pan). Note the plastic guard with the square hole in the side just inside of the filler hole. You have to put the filler hose (whatever you use) into that square hole but be VERY CAREFUL not to bump the white plastic piece upward because it can get unseated and be knocked into the pan. http://img115.imageshack.us/img115/5399/CopyofTransfillerhole.jpg
