2microntech - Helping to Keep Your Common Rail VW Alive!!
Kevinski4
Nebraska
I'm curious if the cp3 could be retrofitted to the v6 cr TDI.
Yes but not with the kit above. Earlier Euro V6 TDIs had the CP3. Grab the parts you need from UK Ebay and they bolt on without too much trouble.
ATR
Baltimore
2011 Golf TDI 6MT
Anymore details? Example would be what date range or anything else helpful?
Macradiators.com
Romania
2.0 CR 360hp
CP3 kit on newer V6 will not work without proper software. I run the cp3 on v6 2011 ccwa engine but i have custom software for it to run flawless. Better to stay away from it as it is not easy.
sootchucker
Colorado
2015 Golf
if somebody can give me measurements to these devices, i can make them. without that.... we are all sunk.
adrian537
los angeles
2014 vw jetta sportwagen tdi
i have the 2micron pureflow and containment kit installed on my car. i am curious to know if my CP4 pump goes bad and i would take my car to the VW dealer (since i have the extended warranty) how would VW deal with my car. i assume they would look at my car, see that is "modified" because of the 2micron system and not want to touch my car? maybe i shouldn't have installed the 2micron pureflow and containment kit since i have the extended warranty? my DPF went bad recently and when i took the car to get it fixed thru the extended warranty they saw the Cim-Tek 70025 filter the 2micron system uses and when they saw "Bio Tek" written on the filter they were trying to accuse me of using bio-fuel that led to my damaged DPF.
mz1
San Antonio,TX
2011 GTD Stage III / 2015 Touareg TDI LUX Stage II
I just bought a CP3 pump kit and will not need my 2micron pureflow and containment kits so if someone is interested I will have 2 for sale...just want what I paid for them that is all...do send me a pm if interested
adrian537
los angeles
you know you could still use the pureflow only as a pre-filter with your CP3?
mz1
San Antonio,TX
My CP3 kit did come with the purflow kit that is why I will sell my two complete 2micron pureflow and containment kits....but thanks for the tip
Terry270
BG, KY
03 golf, 10 A3
Wouldn't hold up in court and they know it. Extra filtering has zero negative affects on anything. But also I would remove the kit honestly as long as it's under warranty. Would be great to have a brand new entire fuel system installed right before the warranty is up lol
mz1
San Antonio,TX
The downside of having such a time bomb (OEM fuel pump) is that even if and when vw should cover this malfunction under warranty (which is not 100% the case - they have gotten away in many cases blaming it on bad fuel quality) you risk being stranded in the middle of your journey or long vacation and being out of your ride for days.
Growler
Got Soot Vendor
Millersport, Ohio
it seems he only made a few of them for the 2015.
I got ahold of one but haven't installed it yet.
jgiffard808
Hawaii
Jetta sportwagen
Hi I just recently picked up a 11 jsw tdi and was wondering if I could pick up one of the fuel filter kits from 2micron or if there was any alternatives? Been trying to research but this is all new to me. Thanks for any help.
KeyTDI
Irvine, CA
2012 Sportwagon
Me too...
His website is gone.
Does he still make or have them?
If not, anyone got one sitting around, PM me!
MichaelB
SE Wisconsin
2014 Passat SE DSG
Just curious. Has anyone who has installed Andrews filtration kits had a HPFP failure and the filters saved the engine from catastrophic damage?
Kriesel
Afton, MN
2006 Jetta TDI
Yes. I had a pump fail with the kit on it, and it saved the engine.
bobt2382
NJ
2010 CW GOLF 4DR 6MT TDI
So is he still making and selling them????
No, he is no longer making these kits. Best you can hope for is to locate a used one. Keep searching the parts for sale forum. Good luck.
RabbitGTI
Wisconsin
B4 Passat Sedan
Another expensive option is to swap the HPFP for a more robust version, correct? Is there a thread on doing that?
rafaelchio21
France
Passat CFGC
Hello guys,
I have a Passat B7 CFGC 2014 and I want to install an additional filter before my CP3 upgrade pump
Is there someone still selling these kits?
bobt2382
NJ
turbovan+tdi
Abbotsford, BC.
If anyone has specs etc, I have someone who's interested in making them.
