DoctorDawg said:I've been making some further observations of the DPF via VAG-COM since the OP, and have learned a few things:
3. OK, this one's really interesting. When you log the pre-DPF and post-DPF temperatures while driving, when the engine is under load (accelerating or climbing a hill) you'll observe that the pre-DPF temperature is higher than the post-DPF temperature...no big surprise here. BUT...when the engine is not under load (while coasting, driving on the flat with no acceleration, or idling) the pre-DPF temperature drops more than the post-DPF temperature does, so that the post- temperature actually ends up (and stays) higher than the pre- temperature.Doc, forgive the basic physics, but don't you think Boyle's law might partly describe the reason for the change in temperature across the DPF under low load situations? I'll check, and I kind of half remember, but I think the basic formula derived to PV=nrt.
We can manipulate this formula to show that hotter post combustion events under high load are more exothermic in front of the DPF: PV/nr = t, so the INCREASED pressure times the STATIC volume divided by INCREASED particles (?) gives an increase in temperature. This discounts the momentary increased pressure effects of more soot in the DPF which will clear up partially due to "passive" regeneration as you observed. Second, under light load situations, cooler post combustion events shift back to the obstruction caused by the DPF, the pressure increase occurs there and the increase in t occurs in the DPF and behind as measured by the post sensor. If soot is always burning there too it could add to the increase in t as well. So, Boyle's law could be at least be a partial explanation for "passive regeneration".
