slow
I've had some odd electrical problems with my 99.5 Jetta TDI. The most obvious and aggrivating of the bunch deals with my radio and stock CD changer. When playing CDs, the changer seems to "skip" but the CDs play fine on all other CD players. It isn't a normal skip either, its almost like the changer loses power then resumes very quickly (within a couple seconds). Also, when trying to adjust the base or treble (for radio, CD, etc.) the level is locked on either A or D (I don't remember exactly). Both the AM and FM reception is horrid, but I checked to make sure the antenna is grounded correctly and it is (holding balance for 10 seconds then hitting CD twice).
Also, the car starts very rough. It will usually turn over for a few seconds the it seems to jerk to a start. It runs fine afterward with the exception of the CEL for a possible bad glow plug/harness/relay (I'll find out this weekend).
Do you guys have any idea what's going on? Could it be a bad battery, relay 109, or loose wire?
