Bypass filter kit install
Gta88ws6
Wichita, ks
14 SportWagen tdi
Is there a way to disassemble the oil filler cap, so as to better drill the hole for the return fitting that goes through it on a Amsoil brand kit?
Sent from my SM-G950U using Tapatalk
Satsonic
Chicago
2006 Jetta TDi (BRM) - DSG Trans (02E)
Do you have a link to the kit that you’re referring to? I’ve seen some kits that actually have adapters that you add on the bottom and then the filter housing on top and that way it’s a seamless engineered solution.
Ol'Rattler
PNA
2006 BRM Jetta
Why are you Installing such a non value added filter kit to your car? Is the ability of the OEM filter to be reliable to 400K miles not enough? I have no clue why folks think that there is some valid reason to add additional filtration to their OEM oil system.
Please don't drink the Amsoil KoolAid. I guess if you already have the Amsoil hat and jacket and are in the habit of randomly spewing Amsoil marketing nonsense, you are already lost. If you can get your self free from the Amsoil cult please do come back for some actual real world discussions on topics relating to your car.
Satsonic
Chicago
I have to agree with Ol’Rattler. I’d focus on using good oil (Rotella T6 - 5w40) and changing it and a good Mann filter every 5k miles. I know that people will say that you can run to 10k miles, but I’m just sharing what I do.
Ol'Rattler
PNA
2006 BRM Jetta
Agreed, except for the 5K mile oil changes. At 188K miles my engines does seem to be just fine with 10K mile oil changes. Would 5K mile oil changes saved my cam? My best guess would be probably not.
KLXD
Lompoc, CA
'98, '2 Jettas
If that filter made the oil not opaque I'd be impressed with it.
Not saying it would do anything to improve the life of the engine, just that it would show it was doing "something".
phaser
Oregon
2004 Jetta PD - 490k
Background: this uoa is from four years ago, at which time I was testing extended mileage on that particular oil.
This is a post Amsoil bypass filter sample. Take a peek at the particle count.
http://pics.tdiclub.com/showfull.php?photo=108052
Now I'm running Schaeffer Supreme 9000 5w-40 and 10k OCI.
coolvdub
SoCal/Bullhead City AZ
2001 Jetta TDI/2013 JSW
I run 20k miles with proper oil and Mann filter.... 556k miles so far. *shrug*.
Glad to see I'm not the only one going the extended OCI route. I do 15k on my TDI and have not had any problems in over 200k miles. This is my low mileage car. I gave my son my '02 1.8T Jetta with 419K on the original engine using quality synthetic oil and filters and it is going strong still doing the same 15k OCI.
Ol'Rattler
PNA
2006 BRM Jetta
Sounds like you need to be de-programed from the Amsoil cult. Do you have the Amsoil hat, jacket and randomly spout random Amsoil nonsense?
Geordi
Somewhere between Heaven and Hell. But it is reall
14 JSW DSG, 03 Wagon 01M, 400k and IPT performance auto!
I look at that report, and I see numbers that seem to be higher than previous reports. Which "particle count" specifically are you looking at?
I have the Dieselgeek bypass filter kit on my ALH wagon, and I must say that I feel a bit depressed about the supposedly "amazing" filtration that happens, it doesn't keep the oil from turning black in the slightest. Dieselgeek's kit uses the Amsoil filter, which seems to be a very overpriced regular filter.
I'm with some of the others, if the result was oil that stayed honey color, I would be much more impressed with the quality and the results. Otherwise... Pfft.
I use quality oil and change it on schedule. That seems to be the best option, for an engine that has now found 400k miles and is still in amazing shape.
Satsonic
Chicago
Are you on all original engine components? Meaning CAM / Lifters etc? Was the 556k miles mostly you or did you buy it with a ton of miles? Not trying to call you out - just trying to learn whether I can make any improvements on my oil change habits.
phaser
Oregon
Note the lube time.
And note the particle count at the bottom of the report. That's where the 2 mic filter does the real job.
Gta88ws6
Wichita, ks
14 SportWagen tdi
Well, with the results and clean from my deleted truck running a bypass filter and the fact I've not seen any other uoa that had over 100k miles on 1 single oil change, ill stick with the Amsoil.
Since no one else has any scientific evidence to support their claims of a better oil, I'm all ears if you want to post factual data.
Also, t6 5w40 rotella, it's junk, it shears down a grade in viscosity in 10k miles. I'll not be using that junk oil that can not maintain viscosity.
oilhammer
outside St Louis, MO
No, I bought the car pre-tooefed at 383k, courtesy of a dealer tech installing the timing belt incorrectly (tensioner tensioned backwards).
The cylinder head was beyond reasonable repair, it had a couple cracked pistons and three bent rods. It got a reconditioned head, new rods, new pistons, new rod bearings (although the originals were fine, but one was damaged from the severity of that rod's shape), new oil pump drive chain and tensioner. The block, crank, mains, are all original. The engine (other than the damage caused by negligence) looked perfectly fine otherwise when I tore it apart. I never even removed it from the car.
I service a LOT of these cars. The factory oil system is perfectly adequate, I see FAR too many of these engines with 300k, 400k, 500k miles to think otherwise. Plenty of things that go wrong on these cars, plenty of things that could use improvement, but this really isn't one of them. I have actually seen more issues with added on things of this nature causing a problem, like an external line or fitting suddenly breaking and causing a massive loss of oil.
Satsonic
Chicago
Thanks for your response. Didn’t realize that you were a VW tech. I grew up changing oil at a local place through high school and our motto was always “oil is cheap when compared to engine components” I guess old habits are just hard to break. I’ll see how I can extend my interval, sounds like it won’t be a problem.
I was just going to do an EGR cooler delete, intake clean out and MPG eco tune on my 06 TDi. Any thoughts or experience on this?
Lex Tdi
Lexington ky
2013 Passat
This is why we cant have nice message boards.... rotella is all i ever used in 800,000 miles in my 2 a4's i had, zero engine issues. It's great you want to go 100,000 miles on a single oil change but when you break down what the cost per mile is to drive by doing it to VW recommendations you are talking factions of a cent difference.
Satsonic
Chicago
LOL - I couldn’t agree more. They make an excellent product that has been tried and tested. LOL
Ol'Rattler
PNA
2006 BRM Jetta
Another marketing thing I remember from back in the day was that If you are one quart low 1/5th of your engine oil protection is gone. :rolleyes:
coalminer16
Central Wisconsin
Golf 2004
Too much can cause foaming and then starve to engine of oil.
I still hear commercials stating to get oil changes every 3000k miles. I do my car at 10 k like the manual- although I likely should do what oil hammer does at 20 k since that is what across the pond does. I do my Honda van when it tells me which is around 7500 miles. Still going at 230k miles good. Funny thing is not all Honda dealers carry engine oil to sell to customers.
