Hey tdi'ers,
I couldn't find a thread that dealt with this so I decided to start a post. I just cracked my pan slightly (again!) and aside from the obvious on getting a steel pan or cover, and not being an idiot, I'm looking for some help. I've taken all the bolts out, and the oil pan is officially stuck on. I can hardly get this thing to budge, not even enough to slip in a screwriver in the seams and work my way in.
Yes, I got all 20 bolts(and the 4 that are tucked away), and the 3 larger that are on the side. This thing is on there so good, if there wasn't a small crack in it, I'm sure I'd be fine not putting the screws back in, and driving around (if it weren't leaking).
Any ideas? Suggestions? I just replaced it in august and it wasn't this hard taking it off last time. Peeled off all the gasket-maker stuff on the outside that I could. Thanks!
