ken.fresno-tdi
- Joined
- Jan 3, 2006
- Location
- Fresno, CA
- TDI
- 95 Eurovan EVC camper with 98 AHU engine (VeganVan02); 01 Jetta ALH engine and parts - waiting for transplant into 97 Eurovan (VeganVan03);05 BEW Beetle
What exactly is the difference between the AHU and the 1Z engines? The reason I ask is that I have a 97 Passat with what may be a bad engine (lots of bluish black smoke) and would like to look into a donor long-block or entire engine to replace it. I may have access to one from a 98 Jetta TDI. My understanding is that the Passat's had the 1Z engine and the later Jettas in the U.S. had the AHU. I will check to make sure the engine is indeed an AHU, but assuming that it is, are there any differences that would make this swap not work?
Thanks for the help.
Ken
Ken
