Don't KNEE-JERK!
Most of the clogging is the result of MANY years, years which also included heavy sulfur fuels and less forgiving oils. Driving style also has a LOT to do with it.
There are people on these forums that have a lot of miles and have never had to clean their EGR valve and intakes: one person is one of the highest of high gurus.
If you're looking to totally eliminate ALL oil from your intake then you're going to have to remove/disable your turbo. Turbos pass oil (of course, healthy ones don't pass much, but if the goal is to eliminate ALL oil then that doesn't matter).
ULSD - check!
Improved oil - check!
How to mitigate:
1. Clean everything.
2. Periodic spirited driving such that you push some good boost will help push through oil.
3. Make sure engine gets ample time at full operating temperature. (short-tripping is not good- this is true for all ICE engines).
4. Get a tune that reduces EGR function, such as Malone's Dynamic EGR.
All of those above things are things that I've done (on two of my cars). My car came to me with 114k miles and it was severely clogged (mostly city driven, by a woman). I now have 168k miles and I have zero reason to even check to see how things are holding up: performance is great, starting is great, FE continues to give me 50mpg+ (3 year average is over 50mpg). At 153k miles (we got it with 143k miles) the wife's car's EGR and intake were pretty clogged as well but performance was still very good (and FE was good). It's now got 208k miles and it's doing the same as my car. I fully expect to never have to clean the EGR valve or the intake on either car, ever again. Keep in mind that, with the wife's car, it went 16 years and 150k miles (and performance was still fine).
Tweaking the EGR via Adaptaion (VCDS) doesn't work. There's a thread around that goes into all of this. ECU really needs to be programmed to do it correctly: one can get a tune for this or have it included in a performance tune (that's what I have on my three Golfs - two other MKIV TDIs in the family are also setup this way).
