sisyphus
- Joined
- Dec 8, 2008
- Location
- Appleton, Maine
- TDI
- 99.5, '01 A4 Jetta sedans, 5 sp box, Hamman mod, Joey mod, Bilsteins, 2.00" lift
I recently resurrected an '01 Jetta w/ 250k miles on the clock. Had a busted up exhaust and a non functioning starter, and has a bad fan control module. Otherwise it's fine, I think. While I had the exhaust apart, I noticed I could see straight through the catalytic converter, no baffles, nothing. Has no codes, no CEL.
Anyway, it smokes a lot on startup, and continues to do so when I just drive it around. It's especially noticeable on the overrun, or when I give it lots of pedal. I can also hear the turbo spooling really well.
I think the exhaust is aftermarket because the downpipe doesn't have any provision to accommodate the mount on the subframe, and I had to add the mounts on the crossmember. Other than that I think it's okay.
Is this a timing issue? Turbo? Exhaust valve problem? I also noticed that the oil is right at the top of the cross hatched pattern on the dipstick, and the former owner seemed obsessed with oil level.
Ideas? Should I sell this thing right away or run it?
