GoremanX Veteran Member Joined Mar 17, 2013 Location Vermont TDI 2001 Audi A4 Avant quattro w/BHW TDI & 01E 6-speed May 23, 2015 #1 Putting a BHW engine back together. Anyone got a part number for this? Looking for #6 in that diagram. Mine's all bent and broken.
GoremanX Veteran Member Joined Mar 17, 2013 Location Vermont TDI 2001 Audi A4 Avant quattro w/BHW TDI & 01E 6-speed May 26, 2015 #2 Anyone?
T Tom_B Veteran Member Joined Aug 24, 2004 Location Central Oklahoma TDI 15 Touareg, 14 A6 May 26, 2015 #3 You might try the link below. The info has not been updated but I've found it useful as a starting point in the past. http://www.passatworld.com/forums/b5-information-base/228021-oem-vw-part-numbers-etka.html
oilhammer Certified Volkswagen Nut & Vendor Joined Dec 11, 2001 Location outside St Louis, MO TDI There are just too many to list.... May 26, 2015 #4 06B-103-551-G It is the same as the AWM 1.8t engine, if you are scouting for a used one.
GoremanX Veteran Member Joined Mar 17, 2013 Location Vermont TDI 2001 Audi A4 Avant quattro w/BHW TDI & 01E 6-speed May 26, 2015 #5 Thank you! And thanks oilhammer for pointing out it's the same as the 1.8T, I need another one for that too.
