megaladon6
for awhile I've been noticing some stiction at the rear brakes, thought it was just the ebrake being finicky-if I didn't use it, things were fine. Now with warm weather it's gotten much worse. Driving on the highway, about 30min to work, the brakes begin to drag. Sometimes they loosen up, most times I have to pull over and jam the pedal. I will feel it push past and sink some, and I am good, usually anyway. I have had to do this 2x when had some traffic. I jacked up the rear, left side was tight, replaced the caliper after breaking the bleeder. Right side seemed mostly ok.... the problem is still there though, maybe even slightly worse. Any ideas? front and rear were replaced about 2 or 3 years ago. grease on the one I pulled was fine. I really can't afford to replace parts that aren't bad in searching for this!
thanks!
thanks!
