compu_85
Gadget Guy
I hooked up the headlight switch's rear fog and front fog pins to the BCM tonight, and found a pleasant surprise: the cluster rear fog indicator works! I don't think it actually turns on an output on the BCM so I'll still have to use a relay to trigger the fixture, but having the idiot light work makes me happy
I think the US coding had a provision for the "full" light switch and expected the rear fog to only be able to be turned on when the switch was in the headlight setting: If it is turned on with the switch in parking it sets an implausible switch fault code.
