Metalhead
Friend's car is throwing this code. Checked all vacuum lines, applied vacuum to EGR valve, moved really smoothly (New valve). MAF specified is considerably lower than actual at idle, they match more once the EGR solenoid closes. I assume this just confirms that there isn't enough exhaust going into the intake.
The EGR cooler looked icky, I just pulled off the one elbow and looked. I didn't think it was totally clogged but could that be it?
