Old June 8th, 2019, 13:40   #1
Nrconnelly
Fuel Economy: 34-48mpg
Default Led upgrades
Good afternoon,
New to the forums, did some searching and couldnít necessarily find an answer. Was looking into upgrading my fog lights to match the hids I have in my headlights. Itís a 2013 golf. Anyone have experience upgrading the fog lights to match? I can look up a bulb guide to figure out which bulb I need. Iím just worried about the new lights throwing bulb out codes. Thanks for your time.
Nrconnelly is offline   Reply With Quote
Old June 9th, 2019, 08:44   #2
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
Welcome to TDI.
You cannot just go to any parts supply for bulbs. Some LED bulbs are sold as "CANBUS" compatible.
Which means the have a built in resistor to simulate an incandescent bulb.
You may find these on eBay also.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.Scangauge II
Jetta_Pilot is offline   Reply With Quote
Old June 10th, 2019, 10:56   #3
SilverGhost
SilverGhost's Avatar
Two options:
1) Get LED "bulbs" with built in resistor to trick computer, commonly called CAN buss bulbs
2) Change BCM coding so it doesn't check the bulb and you can put whatever bulb you want in the fog lamps.
Jason
PS: do you just want to look cool because your fog lamps match your HID? Or do you want functional fog lamps?
SilverGhost is offline   Reply With Quote
Old June 16th, 2019, 16:57   #4
Nrconnelly
Actual functional fog lamps would be nice. I’m familiar with the “canbuss” technology. I bought some for a previous car I owned, (a gti) and it still threw a code. I was just looking for some specific lights people bought that worked out for them. Thank you for the welcome and replies.
Old June 17th, 2019, 10:07   #5
SilverGhost
I have found some 3000k halogens for mine that did the intended job of fog lamp, but not much else. The LEDs I've tried usually fall between "looks pretty, but does nothing" and "just there to piss everyone off".
If you're really serious about it, places like Retrofit source will sell you a LED projector module for fog lamps. BTW they can also install it into your housing if you send it to them. I would do that and have the bulb monitoring turned off for the fog lamps.
Jason
Old June 17th, 2019, 14:08   #6
GoFaster
Moderator at Large
Been through this with another vehicle (not VW).
Bought something cheap, found that it did not do the job. The usual problem with cheap LED replacements is that the beam pattern will not be correct for the task at hand - the really cheap stuff will not even be remotely close. The cheap ones had a beam pattern that was so bad that switching the fog lights on didn't make a discernible difference from the driver's seat ...
Replaced with these ... https://www.xenondepot.com/h16-h8-h1...12793unix2.htm
Muuuuch better. Amber/yellow is better for fog lamp applications. These are not cheap.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old June 18th, 2019, 05:33   #7
Votblindub
Votblindub's Avatar
DDM Tuning (not affiliated with them) has HID kits that are super affordable and have a lifetime warranty, if you want to get more light from your fog lights. Obviously, you could blind people if you get a ridiculous set, so be smart about it. They have the yellow color ones, commonly referred to as euro or french fog lights. THOSE are the functional ones. Those are the ones that are best for fog and snow and rain and generally bad weather. If you just want the matching color, you can simply snag some LEDs online that are non-error causing bulbs, toss em in and go on with your day.
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old June 18th, 2019, 16:09   #8
Nrconnelly
Excellent, appreciate the replies. I was considering going with the yellowish colored ones but now after the research and recommendations, that’s probably the route I’ll go. Thanks again all.
Old June 20th, 2019, 05:20   #9
Votblindub
Votblindub's Avatar
I did a bit of reading about fog lights and here's what i found (short version):
-Yellow is the best color
-It's not more light, it's where the light goes
Full details
OEM LED Bi-Xenon LED DRL issue Tomecki827 Upgrades (non TDI Engine related) 1 March 16th, 2019 23:14
Mk6 Golf non-LED to LED xenon coding help veedubu Upgrades (non TDI Engine related) 0 April 22nd, 2012 07:43
LED question for drl, and LED bar tbone1989 TDI 101 2 October 27th, 2011 16:41
Comments on my upgrades/future upgrades Crispy TDI Power Enhancements 9 August 10th, 2007 15:23
© 1996 - 2020, All Rights Reserved
Page generated in 0.15528 seconds with 11 queries
[Output: 92.10 Kb. compressed to 79.03 Kb. by saving 13.07 Kb. (14.19%)]
