Old August 14th, 2015, 02:52   #31
Bueller
If it's sealing completely and not leaking I can't imagine leaving it alone until the next oil change would be a problem. I've re-used O-rings plenty of times.
Bueller is offline   Reply With Quote
Old August 14th, 2015, 09:14   #32
meerschm
meerschm's Avatar
If you did not open that drain on the filter cap, you would not need to do so only to change the o ring.
if, on the other hand, you had opened it up, would be good to use the new small O ring.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old August 14th, 2015, 09:22   #33
copperbeech
Thanks Bueller and meerschm for the reassurance.
(Given that there is no tool/attachment for draining the filter for an MK7 I did not touch the filter drain).
copperbeech is offline   Reply With Quote
Old December 14th, 2015, 16:19   #34
adjat84th
adjat84th's Avatar
Just did our first change yesterday with not much difficulty. Messier with the oil filter and the oil pan insulation absorbing some oil, but not terrible. I was also surprised to see that the oil pan is NOT plastic like I have read elsewhere. It looks to be aluminum wrapped in foam insulation, and then has a plastic cover over that!
I would like to add that the little grey clip on the (charge air system?) coolant pump was somewhat tricky as you have to pull it out and then also squeeze it like a normal connector to pull it off the pump. I just pulled the grey clip out and thought that was all there was to it and it gave me a fit obviously. Also, if not already mentioned, the oil filter cap drain plug is 13mm, and the oil pan drain plug is torqued to 22ft-lbs with new copper crush washer.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old December 14th, 2015, 18:22   #35
meerschm
meerschm's Avatar
http://pics.tdiclub.com/data/517/201...0k_Service.pdf
has a few more photos and a few words. was done on a Jetta, but the same engine and oil filter setup.
Mike
Old December 16th, 2015, 13:30   #36
No More Buffalo
Originally Posted by VW_TDi_ View Post
That information is now 6 years and 2 engine generations out of date. I wouldn't really be quoting it as gospel at this point.
No More Buffalo is offline   Reply With Quote
Old December 19th, 2015, 03:26   #37
Outlier
Originally Posted by obababoy View Post
Hey guys, got my 10k service yesterday and on the oil quantity the number was "60" what unit of measurement is this? Better not be oz!
Volkswagen usually requires the dealers to bill out fluids such as coolant or in your case, oil a certain way for warranty purposes. Your dealer may have the LL03 in bulk, so they have it billed out as 1/10 of a quart i.e. 60=6 quarts. HTH.
Outlier is offline   Reply With Quote
Old December 28th, 2015, 20:06   #38
Victor Huge
Victor Huge's Avatar
TDI(s): Mk7 Golf TDI
The 1.8t has a plastic oil pan from what I read... Sillyness.
Victor Huge is offline   Reply With Quote
Old December 30th, 2015, 08:41   #39
no-blue-screen
TDI Nut
TDI(s): TDI
Anyone have a part # for the oil drain plug? I'm planning to go to the dealer today to use my white dealer card to get all the parts needed for my 20k service.
Posted via my phablet using Tapatalk
no-blue-screen is offline   Reply With Quote
Old December 30th, 2015, 12:02   #40
meerschm
meerschm's Avatar
Have them run the VIN.
or you can enter vin and dive down.
https://consumerlink.oeconnection.com/87058464014618647
here or elsewhere.
I found online access from a dealer to be less cost. (sometimes. today my local dealer set something so now the onliine prices match retail listed on other sites)
check the oil. my dealer started selling the 507 00 oil in quarts vs liters. (same price)
Mike
Old December 30th, 2015, 19:02   #41
RacerTodd
RacerTodd's Avatar
Fuel Economy: about 50
N 908 132 02
Todd
Seattle,WA
'86 GTI, Red of course. (exciting racey car) 274,000 miles
'01 Golf TDI, silver. (new work car) 558,000 miles!
'87 Golf, Polar Silver. (retired work car) 654,000 miles <- Gone to a new home
RacerTodd is offline   Reply With Quote
Old January 12th, 2018, 12:06   #42
wolfr83
Default Great article
Thanks for posting this Jason. I followed you instructions and completed the oil change in about an hour and a half.
wolfr83 is offline   Reply With Quote
Old February 15th, 2018, 17:52   #43
elcid86
Very helpful Thanks. What a PITA that filter location is. Ugh I wish they'd left it topside like my other VWs and E46 BMW.
Shawn in VA/DC
2015 Golf TDI SEL DSG - White Wabbit
2004 BMW 330i ZHP - Red Rehab
elcid86 is offline   Reply With Quote
Old February 19th, 2018, 07:51   #44
cevans
TDI Parts Ninja Vendor
cevans's Avatar
Very PITA - thats why I made this:
https://www.idparts.com/oil-filter-d...88-p-6949.html
IDParts.com - IDParts.com Vendor Thread - The IDParts Blog - IDParts YouTube Channel
Current Diesels: '17 Canyon 2.8L DMax, '15 Jetta, '15 Beetle Convertible, '11 R350 BT // Past: 15' Ram ED, '13 NMS, '10 JSW, '10 Jetta Sedan, '07 R320 CDI, '06 E320 CDI, '03 Wagon, '00 Golf 2-Dr, '00 NB (Yellow :-)
Stop Hunting for Torque Specs - Get A Free IDParts Torque Spec Poster Today!
cevans is offline   Reply With Quote
Old February 21st, 2018, 15:50   #45
PHAT-DUB
PHAT-DUB's Avatar
has anyone installed one of these
https://www.ezoildrain.ca/search?q=M...&submit=Search
www.badgeskins.com
Custom MK4 widebody for sale - here
PHAT-DUB is offline   Reply With Quote
Margey's guide to fuel filter change outs LargeMarge VW MKV-A5 Golf/Jettas 24 January 18th, 2010 18:33
error in timing belt change guide zeaustar VW MKIV-A4 TDIs (VE and PD) 2 April 30th, 2009 12:15
Need TB change guide in Brighton, MI area. master cylinder VW MKIV-A4 TDIs (VE and PD) 6 May 9th, 2004 08:47
Page generated in 0.17953 seconds with 11 queries
[Output: 127.79 Kb. compressed to 106.40 Kb. by saving 21.39 Kb. (16.74%)]
