Dont do it mate, it just doesnt make sense...There is so much fabricating and adapting and it wont look OEM. The engine harneses are different so the clocks,drive by wire pedals, fuel lines, exhaust mounts, gearbox, front panel, exhaust, vacuum lines and the list goes on... You will be better off finding a wrecked one of similar age and swap the parts and even then its a pain in the back- broken trims/clips and left over nuts and bolts. Best even save the money and buy one done by the factory. Good luck anyway...
