ctnatureboy
<<<SOLD>>>
Photos here: https://photos.app.goo.gl/SQcVusxv1L7OZ1TA3
254,069 miles. ***SALVAGE*** Title, both key FOBs, and valet key in-hand.
Car starts instantly without hesitation in ANY temperature, idles cleanly, pulls strong, and runs efficiently. NO codes (Have VCDS on hand to verify).
Took glancing hit from the left rear and repairs cost more than the vehicle is worth on the books so I'm selling the whole car for parts.
If you've ever wanted all the best parts to make your TDI perform at its best and last as long as you're willing to drive it, this is the deal for you! Even comes with a FULL tank of fuel AND 3 bottles of Opti-Lube Winter fuel treatment in the Opti Box. Timing belt done at 205,000 miles.
Electrical wire harness, radio, ECM, gauge cluster, etc... are un-mollested. Brakes are in VERY good shape and the E-brake even works (and releases cleanly)!
LUK Clutch and DMF
Garrett VNT-17 Turbocharger
DieselGeek Sigma 5 Short Shifter
DieselGeek Panzer Skid plate with FMJ option
DiselGeek Bypass Oil Filter Kit
OE VW First Aid Kit
OEM VW Vented fender liner
OE VW Rear Calliper Return Springs
Evolution Import 1" Suspension Lift
Koni Yellows
Lower Control Arms with Audi TT Bushings
Kerma TDI Doggie Collar Retrofit
Franko6 Titan Stage 2 Cam with chrome journals
Franko6 Modified No-Drill Cam Bearings
INA Black Oxide Lifters
OE Heated black Leather seats
OE TDI Monster Mats
AARodrigues armrest hinge and latch
Lubrication Specialties 2 micron Cat Fuel Filter Kit
Volxtuning glass headlamp covers
Defender-Tech Lift Pump with fail-safe bypass
Bosal Swan Neck Trailer Hitch Frame
Bosal Turbo-back exhaust
1999-2005 Bentley Service Manual
Torque Specifications Poster A4 ALH
Malone Tuning FlashZilla + cable
Several Tunes inculding variants with Dynamic Idle and Dynamic EGR
MANY unlisted parts have been replaced and/or upgraded.
Also have uninstalled ID Parts high mileage timing belt service kit, extra CAT 2 micron fuel filter, extra Amsoil bypas oil filter, OE VW transmission oil.
All parts sourced from TDI Club approved vendor list.
Car goes complete/as-is.
I will NOT part-out.
Price is non-negotiable.
No delivery available.
LUK Clutch and DMF
OE VW First Aid Kit
Koni Yellows
OE TDI Monster Mats
