TDITALIAN
- Joined
- Nov 7, 2004
- Location
- Los Angeles, CA
- TDI
- 2003 Jetta Wagon, Slv, 5 spd 1999.5 Silver Jetta Sedan 5spd
RUNAWAY Starter motor spinning with ignition KEY REMOVED???
Wife went out this morning to start the car (99.5 Jetta 5 speed tranny) and ran into the house saying "the car doesn't start and strange noise coming from engine compartment" even with ignition key in hand.
Upon immediate inspection I found the starter motor spinning unengaged from the flywheel. Didn't want to burn out starter motor so I disconnected the batttery and spinning stopped. But once I reconnect the battery cable noise immediately restarts regardless if the key is in ignition or not.
Has anyone had this problem or could tell me where to start troubleshooting??? Any help would be greatly appreciated.
