Hamsterdiesel
TDIClub Enthusiast , Veteran Member & HO5G CoFound
This is something I bought for my cat, to facilitate shedding. When someone mentioned using the metal strip from a tape dispenser, I thought maybe I should try this shedding blade.
Let me tell you, it pulled up dust where I thought there was none! I had to clean the car in 2 sittings, because it pulled out SO MUCH dust!
I probably should have used it in conjunction with a shop vac, it would have been a little faster.
Check the link below for a picture:
shed-n-blade
shed-n-blade
