Old June 15th, 2018, 00:22   #16
KyleMillione
Fuel Economy: 02 (auto) 39, 03 (man) 48
The hang up on coasting is normal. It is supposed to stay locked up even while coasting. Essentially the motor drives the trans to get up to speed and the trans drives the motor while coasting in 3/4 gear.
2002 Green Jetta Auto 220k RIP
2002 Black Jetta Auto 240k
2003 Silver Jetta 5sp 290k
KyleMillione is offline   Reply With Quote
Old June 17th, 2018, 21:59   #17
Suadwa
I am trying to scan codes on the transmission but i can't connect to tcm, i tried with vagcom and with odbeleven. Any ideas
Suadwa is offline   Reply With Quote
Old June 18th, 2018, 09:11   #18
flee
Fuel Economy: 40-ish
Using a genuine VCDS?
If so, The TCM has been known to fail but so can the wiring.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old June 18th, 2018, 17:04   #19
Suadwa
Not genuine Vcds but my ODB eleven is genuine and still no connection, but i was gonna go to pull and save and find one there just to try it out, do i need to be looking for specific numbers
Old June 30th, 2018, 23:17   #20
Suadwa
Ok everybody today i replaced my valve body from one that I got on eBay (said it was rebuilt, tested, and cleaned and shipped also came with its own harness ) got it on Friday I installed it today got four codes for all solenoid, after clearing code for solenoid kept coming back, also transmission was in limp mode and wouldnt come out, started in third and that's was it, well after I talked to ebay I am sending that one back, in mean time i installed my back and Tran oil got changed twice in 2 hours total of 7qurts maybe more, and as of right now there is no more surging, and car pulls great and no trans codes... Will see how it goes, my next plan is to change the oil again next weekend..
Old July 1st, 2018, 09:03   #21
jokila
jokila's Avatar
Fuel Economy: 52/45/40
-1 for not listening to the advice on this thread about the ebay valve bodies.
+1 for another lesson in the school of hard knocks, ahem.. wisdom of life.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old July 1st, 2018, 21:48   #22
Suadwa
Yes very true about listening, but i figured I try, and seller offered to send new harness and solenoid but i was upset that, in the ad it say that it's rebuilt, tested and removed and cleaned, and at the end there is issues with it..
2002 TDI Jetta RPM Jumping SilverTurtle TDI 101 6 February 15th, 2014 19:57
dramatic Power loss when pushed above 2,000 rpm 2002 Jetta TDI Boondoggle VW MKIV-A4 TDIs (VE and PD) 6 January 28th, 2014 17:58
PD TDI Vibration @2000 rpm and 3500 rpm+ eparker202 VW MKIV-A4 TDIs (VE and PD) 8 December 10th, 2012 19:33
2002 jetta tdi manual double check at low RPM's when stepping on throttle! rhinotalon VW MKIV-A4 TDIs (VE and PD) 0 June 28th, 2011 14:08
RPM power range for a 90hp 2002 jetta tdi no mods 2002tdijetta TDI 101 2 June 22nd, 2005 11:26
Page generated in 0.12207 seconds with 12 queries
[Output: 80.48 Kb. compressed to 70.10 Kb. by saving 10.38 Kb. (12.90%)]
