Old June 1st, 2018, 04:33   #16
oilhammer's Avatar
Fuel Economy: fantastic
Oh it is within the realm of normalcy for TDI club to make something so simple turn into an 11ty page long thread.
www.cardocautomotive.com
Old June 1st, 2018, 16:37   #17
tdiatlast
Okay, OH, I'm going to continue flogging this dead horse, and...I don't even have a horse in this race!
Have you noticed if the tank internals are better protected from corrosion if continually immersed in AdBlue? I recall speculation early on that running the tank mostly empty vs. mostly full might be a contributing factor in AdBlue pump failures.
For sure, an OCD question, but...your experience is valuable.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old June 1st, 2018, 16:47   #18
MichaelB
Fuel Economy: very good
It might be interesting for you to start a poll.........
1 I keep the DEF tank topped up at all times
2 I refill it at the 10k service interval
3. I wait till the message comes on the MFI
4. I ignore it until it becomes a problem
5. I have had DEF pump issues
6. I have never had a DEF pump issue.
MichaelB is offline   Reply With Quote
Old June 3rd, 2018, 12:23   #19
Rico567
I have filled at every OC since the free services expired. It takes the 2.5 gal. jug just about perfectly. One time it took all but a few ounces, and I just dumped the rest. At $6.99 a jug at Rural King, who cares? Filling is simple for me, as initially I found a deal on the M-B 10 liter jug and hose, which hooks up and self-vents. So, just connect up and let it fill....no spills, no muss, not much to it.
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old June 9th, 2018, 20:19   #20
bizzle
bizzle's Avatar
I have an extra one of those filling contraptions that was just posted that I'd be willing to drop by someone's place in Southern California (or mail it, but then it might be the same price as ordering new).
I don't think you can overfill the tank because the nozzle pushes on and I don't know if it's vacuum pressure or not but eventually it will stop accepting fluid. You can hear it, too, because as the fluid fills there is less air space and the sound will change. It doesn't take but a few minutes.
I got together with a few buddies and we all serviced our Golfs so I had bought those fill contraptions for each of us, but it turns out the process is like 5-10 minutes and doesn't need to be done very often (thought it was going to be like every fuel fill!) so we only ended up using one. I don't think I'm going to fill mine up to the top next time, though. By the time the tank is halfway empty, the fluid will probably be nearing the end of life...unless the tank is air tight and if being air tight makes the difference.
The gauge, btw, isn't particularly accurate. I think it was telling us our tanks were 100% full when they were only about halfway there. Trying to think of anything else, but only other thing is if you *do* manage to spill some on the driveway or whatever make sure you wash it off.
bizzle is offline   Reply With Quote
Old June 12th, 2018, 10:08   #21
scooperhsd
The "store brand" at WALMART that comes in the 2.5 gallon container hase a hose that fits perfectly on my 2015 Golf. Just put the hose into the DEF fill port, open the vent on the DEF container and just lift it up until the container is empty.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old June 12th, 2018, 10:19   #22
MichaelB
If your tank will not accept the full 2.5 gallons you are going to have a spill.
Old June 12th, 2018, 16:53   #23
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
Luckily, he has a Golf, so it's right there next to the fuel filler. Just put the cap back on, run a few ounces of water through the drain hole and motor on.
In my old Passat, the filler was in the trunk, so I had to actually be careful.
Blue_Hen_TDI is offline   Reply With Quote
Old June 15th, 2018, 12:29   #24
berks_tom
Fuel Economy: avg 42 mpg
If you wait to fill until the warning comes on, you won't have a problem fitting the entire 2.5 gallon container into the tank.
Why worry about topping off the tank? The car doesn't need DEF _that_ often.
Mine: 2013 Passat TDI SEL, Night Blue, 140K miles, panzer plate, P3cars gauge, emissions "fixed" by VW
Sons: 2006 Jetta TDI, pkg2, 5spd, 232K miles
RIP: 2006 Jetta TDI, DSG, 289K miles, RC1+
"When in danger, when in doubt, run in circles, scream and shout." -R.A.Heinlen
berks_tom is offline   Reply With Quote
Old June 18th, 2018, 12:38   #25
vinny6737TDI
vinny6737TDI's Avatar
Fuel Economy: 50MPG Highway
My AdBlue 'low' light just came on after 40,000kms from the time I bought the 2013 Passat TDI HighLine. My mechanic offers to top it up at each oil change but in my mind, it's not needed that often. I wouldn't know what the level was when I bought it at 106,000kms.
Don't Make Your Emergency, My Priority
vinny6737TDI is offline   Reply With Quote
Old June 24th, 2018, 17:41   #26
brownnugen
Here is one data point here: on my 2015 GSW, my DEF warning came on around 15,200 on the odometer, letting me know I had 1,500 mile remaining until empty. I drove it another 200 miles (1,300 miles till empty) and bought a 2.5 gallon cube at Walmart. After putting all of it in the tank, the MFI indicated I now have 10,000 until I run out of DEF. so, if my math is correct, each 2.5 gallon cube should be good for about 8,800 miles. Id round down to 8,500 miles.
brownnugen is offline   Reply With Quote
Def pastduebill VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 3 February 20th, 2018 05:30
FS: Top mounted turbo manifold, similar to 1z but turbo bolts on top SmokeFree Vendor & GroupBuy items for sale 6 February 25th, 2011 12:30
castol txt on top of motul on top of castrol engineerorange Fuels & Lubricants 5 April 6th, 2006 11:53
Optima Orange top is now Red Top reversed gearhead VW MKIV-A4 TDIs (VE and PD) 0 February 18th, 2003 00:47
Vagcom Lap top or desk top? Glennbo TDI 101 1 July 28th, 2002 05:35
Page generated in 0.13938 seconds with 12 queries
[Output: 107.11 Kb. compressed to 91.20 Kb. by saving 15.91 Kb. (14.85%)]
