2010 Jetta TDI 2.0 best fuel economy?
tlcallahan10
Clarksville, TN
2010 Jetta TDI
I have a 2010 Jetta TDI 2.0 I am like meny people trying to get the best fuel economy out of my TDI. I am also new to TDI can anyone give me any tips or mods that i can do to get better mpg's. I was thinking of lowering it 1.5 and tinting the windows for looks and better mpg's. I was also looking at revo and a K&N maby a bigger exhaust? Any info would help!
Softrockrenegade
Howellbama, NJ
None...2011 Golf DSG (replaced by VW W/) 2013 Passat SE 6M(bought back) Current 2017 sportwagen TSI 4Motion.
Slightly increase tire pressure (40psi) , stay under 70mph on the highway , no k&n filter.....bad bad bad ,
Damonmorder
Phoenix AZ
06 Jetta
From everything i have read these cars and like most diesels alike have about 200-300% more air then necessary with a clean stock filter and box. From my research of the TDI's these air boxes and intakes have more then enough airflow for stock to light moderate tuning/performance. K&N's are a joke IMO(Resource; Diesel mechanic & went to Diesel and Auto Tech school) firstly, you have to oil K&N's for them to capture dirt, this oil can potentially get on a MAF(mass air flow) sensor and cause it to read inaccurate or not work. How the sensor works(ik there is cold wire sensors and a few different MAF variations but the majority is Hot wire) is a hot wire that with incoming air charge removes heat which detects air volume and density and the computer can determine the density of the charge by resistance in the wire and the oil can coke on that wire which affects performance of the sensor. Second i have done many dyno runs on modern vehicles mind you, and most of the time i have not seen a increase with K&N's and if there is any its 2-4hp(IK ill get some flame posting this about how ur suburban gained 40hp on a K&N) Sorry personal experience. I have found a Tune + more efficient intake system will result in higher HP if you also have the Exhaust upgraded to expel the excess air(a internal combustion engine is a air compressor after all). Thirdly if you go to K&N's web site it says in black and white the dirtier the air filter gets the better it cleans... totally agree with that but the point is a freshly cleaned K&N WILL let dirt in and for turbo'ed vehicles dirt does nasty things to the compressor side of the turbocharger. If you dont believe this get micron ratings from K&N's and from VW's stock filter and compare.
As for the exhaust side, from my research on the TDI's a larger exhaust tube(inside diameter) it has been said it causes faster turbocharger spool up and can increase efficiency if there is no restriction components(muffler/Resonator). I've heard the toss up back and forth about the CAT being a restriction component, potentially I suppose but if its a good clean cat it "should" be very slight. The turbocharger is a natural backpressure device so better flow after the turbo helps turbo efficiency.
From my limited experience the best and cheapest mod is to remove some lead from your right foot(cruising speed). Read hypermiling too, I've noticed a increase in mpg by shifting higher around 2000-3000 instead of grannie'in it.
I apologize about my large rant with K&N's again its personal experience and ive seen it time and time again where the MAF's are the victims...
Softrockrenegade is 100% correct about tire pressure and mph use the 120 rule and of course no K&N!! :D
bhutchins
SW Portland OR
Jetta TDiCup, 02Q built Sept 2010
Malone stage 2 tune, keeping the DPF, gained me about 5 mpg highway (if you keep your foot out of it) and maintains emisions.
I regret removing my DPF. It was expen$ive, no longer a clean diesel, thows codes, but gained about another 4 mpg with the dpf delete tune, and lower EGT.
TurboDaddy
Tampa fl/Murphy NC
2011 Sport Wagon
Increase your milage reduce your speed
I have tried driving at all speeds on cruise control. If you maintain 55 on a highway on cruise you can obtain 53 mpg and better.
Damonmorder
Phoenix AZ
06 Jetta
I wish i could do that, I'd get lots of Birds flying at me lol. Hard to even do the speed limit which is 75mph on local freeway :D:cool:
MikeMars
UK
Vento 1.9 TDi (retired), A4 1.9 TDi (rear end collision), VW Passat 1.9 TDi (retired), Audi A2 1.4 TDi
If you maintain 55 using your foot instead of the cruise control you'll probably get slightly better than before (since the cruise control's throttle control is a bit erratic when driving on anything other than totally flat & smooth roads).
740GLE
NH
Get nother retune to reflect the sans DPF, you'll loose the codes, and probably get some more MPGs.
BTW are you saying going with the stage 2 tune netted you +5mpg then you saw and additional +4mpgs with the DPF removed? so whats that 55MPG if you baby it?
tlcallahan10
Clarksville, TN
2010 Jetta TDI
Would retuning the ecu,ecm be the best bet for the mpg's be cause they control everything? If so what would be the best bang for the buck? Also what about lowering the boost pressure?
dr.zed
2009 TDI m6 jetta
4.3l /100 Kms at 55-58 mph for 750 Kms all highway from Toronto to Columbus Ohio.
4.8l /100 Kms at 60-65 mph for 700 Kms from Ohio to Raleigh nc.
Mid sept driving. Some ac on.
5.5l at 65-75 mph for 1400 Kms nc to Toronto
Stock minimal tread 16" continental tires at 40 psi
Smashed Ixnay
Auburndale, FL
2015 Passat TDI SEL
I'm curious about this also. If we hadn't purchased and extended warranty I would be getting tuned as soon as we hit 36k miles on our 2010 TDI with the DSG. Unfortunately we are only at about 29k miles and have another 31k miles before our warranty is up. I plan on getting tuned then, but curious to find out if he is saying he got +5mpg with the tune and then another +4 (9mpg total) from gutting the dpf.
Derrel H Green
Murrieta, California
An '05 MBZ E-320 CDI (W-211) replaced the '10 TDI JSW
Tune it now
I'm curious about this also. If we hadn't purchased an extended warranty, I would be getting tuned as soon as we hit 36k miles on our 2010 TDI with the DSG. Unfortunately we are only at about 29k miles and have another 31k miles before our warranty is up. I plan on getting tuned then, but curious to find out if he is saying he got +5mpg with the tune and then another +4 (9mpg total) from gutting the dpf.
'I'm curious about this also' Why oh why are you waiting?confused: Do it now!
Once you get yours tuned, you WILL wonder why you waited. :p
Are you somehow afraid that VW will find out that you have had yours tuned? :confused:
Here is exactly what bhutchins said word for word: Malone stage 2 tune, keeping the DPF, gained me about 5 mpg highway (if you keep your foot out of it) and maintains emisions.
He then continues on and states:
I regret removing my DPF. It was expen$ive, no longer a clean diesel, throws codes, but gained about another 4 mpg with the dpf delete tune, and lower EGT. (For a total of apprximately nine (9) mpg gain!
What he does not say is the tremendous gains in hp and mainly torque that he saw.
The way I understand it, you must do Stage Two IF you plan on removing your DPF.
So why not get at least a stage one tune NOW and enjoy the extra hp and TORQUE!
I had my JSW TDI DSG done at 36K and then sold it outright at 43K miles
five months later, and I am not at all sorry I paid five bills for that tune.
You will not regret that kind of move at all, believe me. :cool:
I did not gain five (5) mpg, but perhaps three (3) mpg instead. Maybe I drove it a little bit harder.
It was so much stronger, it was hard not to enjoy that extra hp and especially the added torque.
BTW, I had a Neuspeed tune which may be a little bit different from the Malone and Revo tunes.
Good luck.
:D
Derrel
Smashed Ixnay
Auburndale, FL
2015 Passat TDI SEL
Good luck.
:D
Derrel
In a sense, yes I'm worried about VW finding out that it is tuned and if something happens that they will deny me warranty work and I'll be stuck with the bill after paying more for an extended warranty. I'm not familair with TDI tuning. If this was a Ford diesel, then I would know which tunes can be traced and which ones aren't noticable when it is taken back to the Ford for whatever reasons.
I don't care for any DPF because I know how much it chokes your MPG. I didn't know if you could sitll keep the DPF and have it tuned. I guess they aren't much different than truck diesels that have 'green' tunes. If getting rid of it can net me even +7mpg without the dpf I'd be happy. If I could keep it and get around 5 more mpg I'd probably consider that route. I just don't know how much more expensive it'd be to get a stage 2 if I wasn't happy with stage 1.
I'm not worried about how much it cost since I have spent much more for the chip on my truck; it's actually cheap compared to what my F350 cost me to tune, lol.
There aren't any other mods you have to do if you tune it though? With my F350 for it to get the most hp/tq I also got an exhaust and intake. Would the transmission be fine with the extra power also on the TDI, or does any work need to be done to it?
bhutchins
SW Portland OR
Mark is working on the readiness. The car is rated 41 mpg rated stock, I got 46 on the highway after the stage 2 tune (47 once), DPF delete with retune to remove regen, I actually saw 51 on the MFD, but could not confirm with fill-ups
The origanal re-tune was stage 2. Mark has two versions, one for DPF delete, and one maintaining it. After getting the turbo-back exhaust, I got the stage 2 DPF delete tune, and saw the additional increase, I'm assuming only because it is not using fuel to regen.
here in america, we have the Magnusson-Moss act. they have to prove any modifications caused the damage. The stage 2 tune maintains the safety of turning down the boost when the EGT gets too hot. The exhaust helped with the EGT, and now I have a FMIC (front mounted inter cooler) that further reduces EGT. these mods do not gain any more power, just keeps the computer from having to turn down the boost since the EGT does not climb as quickly
leave the emisions alone, and get the stage 2 tune, you'll wonder why the car didnt come this way. If EGT is a problem then go with FMIC, and keep it a clean diesel
bhutchins
SW Portland OR
I'd expect warentee denial if the ECM failed since I modded it, but they did put the fuel line dampners on recently. So, if you mod it, you own it. (I thought I owned my car already anyways)
Saiga542
Southern Wisconsin
I commute 120 miles a day, three times a week and I find the same results as you. For some reason I have been plugging 54 MPH into my cruise based on my Escort Radar/Lidar detector's GPS based speed readout.
One morning I did the commute at 49 MPG, it was a summer morning, and at the end my overall fuel mileage for the leg showed 56.8, but I don't claim that because it was at the very end of the trip and that final roll into the company parking lot is a long downhill glide, if you know what I mean. However, for 10 minutes in the end of that trip I was able to 55 MPG consistantly, so that is the number I'll claim as a win.
tbone1989
NJ/NYC
2011 Jetta TDI 6-speed
Does my 2011 have a FMIC? I was told i do. I really want the stage 2 tune with my DPF still in tact. What exhaust should i get? And is Malone tunning the best to go with?
bhutchins
SW Portland OR
you have a intercooler, but it's sandwitched between the radiator and AC condenser. It has less volume (LxWxH) than the one I installed. the larger the intercooler, the more time it has to exchange heat. I installed similar to this one, but it's only the second they made for a TDi
the exhaust cost/performance ratio is high. I put on performance-diesel.com downpipe and exhaust. not really needed unless you plan on doing injectors, at which time you also need a new clutch and possibly a limited slip diff (LSD).
any of the reputable tunes (rocketchip, malone, etc) here can help you, I just happen to have MaloneTuning.
tbone1989
NJ/NYC
I'm leaning towards Malone, I hear a lot of good feedback. I really want more power, more mpgs would be nice, but I also want to hear my turbo more. Not like a stage 3 evo or anything, just a nice suddle spool.
740GLE
NH
When it's 10F degrees out, and my IAT are around 15F I don't think a larger IC is going to do a whole heck of a lot.
Have you any impreical evidance that your IAT have dropped dramatically during the summer months? I'm sure it'll help on long hard pulls up a mountain, but not a whole lot of heat is generated when cruising on the highway at 60-70mph.
ZuMBLe
NY
Golf
New to diesels but very familiar with turbo petrol cars. The IAT sensor is normally where the MAF is which is before the turbo. The intercooler (in a petrol turbo application) is placed after the turbo and cools the air from the turbo. You probably won't see IAT temp changes from a IC change.
740GLE
NH
This is from the self study guide on VW's CR engines.
These cars have both a MAF and a MAP. The MAP is used to control boost levels. It'll also dial back the boost if the IAT seen at the MAP is too high.
Seening a person who's concerned with economy will be using as little boost as possible (boost comes from heat of the exhaust, extra heat kills MPGs) there will be very very little heat passed through the system.
Now if a person is modding their car for performance, economy will take a back seat, and shedding the extra heat from higher sustained boost leves is needed.
So I don't think increasing the IC capacity is any sort of economy mod.
MikeMars
UK
Indeed, the IC and the turbo will hardly be used when driving for economy. Hence the frequent advice on the economy forum to sometimes thrash the car in order to unstick/decoke the turbo...
ZuMBLe
NY
Golf
Thanks for the pic. Slowly learning more about these engines.
bhutchins
SW Portland OR
correct, the larger IC will not change economy, only help keep the ECU from turning down boost due to EGT
Bravo19r
Burnaby, British Columbia
Y2K4 Jetta Variant TDI (RIP), 1996 B4V 1.9 TDI (Re-Homed), 2010 Jetta TDI Highline
2009 TDI m6 jetta
My 1996 Passat Variant M5 1.9L VE "1Z" with 400,000km with a stock tired IP and stock worn out injectors running Stage 1 Malone Tune with Dynamic EGR and 16PSI Boost;
1) Bellingham, WA to San Francisco, CA = 1528 KM using 70.99 litres of fuel for an average of 4.65 L/100km (50.58 US MPG), Tyres at 35psi, cruise control at 62MPH (100KPH)
-Bellingham, WA to Mount Ashland, OR with a stop every three to four hours.
-Mount Ashland, OR to Oakland, CA with a stop every three to four hours.
2) San Francisco, CA to Bellingham, WA = 1524 KM using 69.42 litres of fuel for an average is 4.56 L/100km (51.58 US MPG), Tyres at 39psi, cruise control at 62MPH (100KPH)
-Oakland, CA to Medford, OR with a stop every three to four hours.
-Medford, OR to Bellingham, WA with a stop every three to four hours.
