MRIBOB
Someone have advice on what this means and a easy safe way to fix it?
Or is this a dealer required fix?
HERE IS THE CODE
Address 15: Airbags
Control Module Part Number: 1C0 909 605 F
Component and/or Version: 04 AIRBAG VW61 0202 0001
Software Coding: 12340
Work Shop Code: WSC 00066
1 Fault Found:
00589 - Airbag Igniter 1; Passenger Side (N131)
32-10 - Resistance too High - Intermittent
----This was posted on the other thread-----------
Possible Solutions
Check Wiring from/to Airbag Igniter Passenger Side (N131)
Check Airbag Igniter Passenger Side (N131)
_______________
Now:
Anyone know where to begin?
I have found from searching that there are wires under the seat to check and clean with contact cleaner.
Do I pose a risk of blowing up the air bags or is this a safe procedure?
Thanks for any help.
HERE IS THE CODE
Address 15: Airbags
1 Fault Found:
Possible Solutions
_______________
Now:
