cheap. then cheaper...
hahaha.... yes, on a scale from 1 to cheap, Im cheap. lol.
I agree with money bags though(Seatman), for the $30 to just put a new one in while its out, thats good money spent.
You forget that you are going to loose 1/2 gallon of coolant, and at $40 bucks at the stealership, thats another $20 just for the coolant.
So now the $30 part plus the $20 in coolant you are looking at $50 bucks in parts. add Shop time at $80 per hour, (around hear anyway), Toronto is Higher, Dealership is 100-120) , Probably 7 units of labour time to re-re. It
typically is more advantagous for the shop to sell you a new T-Stat, than worry about a partial.
Once you replace the T-Stat, then you know you will have proper cooling / heating flow through the system.
Depending on the Mileage, welcome to the world of VW.
PS. OP was regarding throwing a CEL , the ECU won't know that it is being lied to by the sensor. It just will assume a certain temperature, if the FUel Sensor, Radiator Sensor, say something different than the ECT Sensor (Dual Sensor, one output for dash, other output for ECU).
Since it probably is the Black plastic (original Version), the New ECT sensor has been up graded (Green Plastic Body) in the '00, It could be BOTH went out. According to Fuelly you only have a few fillups using fuelly, this means the vehicle is not 1st owner, and you are now getting all of the fun of VW ownership. Who knows if the ECT was replaced ever before. Check the Date code stampe on the Hex flange or plastic of the Sensor when you remeove it. If it xx00 or xx01 where xx is the week of the year or julian Day ofthe year, might give an indication if its original (99 or 00), or been replaced once or twice in its life. (07, 08,09). Sometimes the sensor parts just fail after 1 year, others 10.
