gbillman
RIP, Gone But Not Forgotten
- Joined
- Dec 8, 2000
- Location
- Troy, MO 63379
Been having problems with this Passat for a couple months now. Originally couldn't even get to start, but solved that with a new fuel temp sensor in the injection pump.
Now, the problem is intermittent loss of power about anytime, accompanied by either DTC 310 (Catalyst Temp Sensor G20) or DTC 550 (Injection Start Control), or both. Sometimes the CEL sets, sometimes not.
The loss in power can be very intermittent on days above 20 deg F or so, and the car continues to run. If the temp is low, the power loss usually results in stalling. Car can be then restarted with lots of cranking, but immediately stalls again.
The stalling and total power loss seems to be connected with the DTC 550 more often than DTC 310, but I'm not real clear on this. DTC 542 does not accompany DTC 550, so the needle lift sensor G80 doesn't seem to be an issue.
The timing, once I can get the car to run on a good day, is perfect, slightly above center on the graph.
Since this is an intermittent situation, checking the catalyst temp sensor resistance and wiring has never shown a problem. But maybe just because it is intermittent? Also, the DTC 550 code test says to check the Cold Start Injector N108 in Output Diagnostic Test Mode, but am unfamiliar with how to do this. Can this be done on a VAG COM?
Is anyone out there familiar enough with such a situation to hazard a guess as to whether I have a Cat Temp Sensor problem, a Cold Start Injector problem, an ECM problem, or something else? I know sometimes the thing the DTC points to is not always the real problem.
