Momentslater
I made a stupid and ran it out of fuel, I put fuel in and attempted to start with cranking to no success. I don't have a vacuum pump and have no way of getting one. How can I prime the system without a vacuum pump?
Tools needed: 17 MM or 11/16 wrench.
Remove Mikey Mouse clip and fill filter.
Remove return fitting. This will allow fuel to flow through the pump easily. Crank engine until you get a good flow of fuel. Tighten fitting.
Loosen nut at injectors. Crank until good fuel flow. Tighten nuts.
Start engine.
That is not how the priming is done with a vacuum pump. The hard lines are tight. It's after the pump is full of fuel is when the hard lines are opened. Usually only one or two while the car is being started.Vacuum is NOT the best way to prime the VP 37 injection pump. Due to the design of the hydraulic circuitry (as opposed to earlier VE pumps) when the injection lines are loose at the injectors and vacuum is applied to the pump housing, some air will be pulled into the open injector line (the pump does not have positive check valves in the hydraulic head. Therefor the best way to prime any VP 37 equipped fuel system is to use pressure. See the below instructions (this is what i send to all of my customers who purchase pumps, or my reseal service)..
PRIMING THE PUMP. The best way to prime a drained pump when installing it back on your engine is with pressure (NOT VACUUM). This is a simple task and is very effective. After installing the pump back on the engine reconnect all lines EXCEPT for the supply hose at the front of the pump (this hose comes form the filter to the front of the pump). The injection lines should be connected to the pump and injectors, and tightened at the pump, but DO NOT TIGHTEN the lines completely at the injectors (finger tight). Now take a squeeze bottle (an empty gear oil bottle with a short piece of 1/4 inch fuel hose attached works very well. Fill the bottle with clean fuel and attach it to the open pump inlet, then slightly loosen the return line fitting form the top rear of the pump so that air can vent out of the threads (just loosen it a turn or so). Now start squeezing the bottle until you see fuel dripping from the loosened fitting (you will hear air "squeaking" out before you see fuel). Keep squeezing the bottle until you see fuel coming out of one of the injector lines (it will be the #1 line if the crank hasn't been rotated form TDC after you installed the timing belt, but it doesn't really matter). Once you see fuel out of one line, tighten it, then rotate the crankshaft clockwise until you see fuel coming from another line, then tighten it. Do this until all 4 injection lines are tight. Your pump, lines, and injectors are now full of fuel and your engine will start very quickly now (the system is completely primed. IF YOU REPLACED YOUR FUEL FILTER AT THIS TIME, use the exact same method described above but connect your squeeze bottle to the filter rather than the pump. You can also use an electric fuel pump if you happen to have one laying around.
Thats my point. The vacuum system doesn't prime the lines at all which means (the pump has to fill them).The pressure method fills the pump and lines completely full of fuel, so the injection pump doesn't have to. Try it, you'll be amazed at how much quicker the engine starts.That is not how the priming is done with a vacuum pump. The hard lines are tight. It's after the pump is full of fuel is when the hard lines are opened. Usually only one or two while the car is being started.
I suppose if i had a battery operated pump i could do that. It's easy to buy a miteyvac at a local parts store. I use the miteyvac to bleed brakes, test vacuum operation of hoses, so it's really a useful tool.Thats my point. The vacuum system doesn't prime the lines at all which means (the pump has to fill them).The pressure method fills the pump and lines completely full of fuel, so the injection pump doesn't have to. Try it, you'll be amazed at how much quicker the engine starts.
I had to change the fuel filter on my old VW pickup on the road once.Therefor the best way to prime any VP 37 equipped fuel system is to use pressure. See the below instructions (this is what i send to all of my customers who purchase pumps, or my reseal service)..
I should have added "clean fuel". You can also do the squeeze bottle method into the filter.I had to change the fuel filter on my old VW pickup on the road once.
I had a GM fuel filter for the 350 Olds diesel, only inlet & outlet lines.
I took the return line off the pump and blew into the tank.
When fuel started trickling out of the pump I put the line back on quick.
Loosened the injector lines and jumped the starter solenoid until I saw fuel coming out and stopped.
Tightened the lines, cranked it several seconds and it started.
The only thing I don't care for with your procedure is not running the bottle of fuel through the filter.
