mpriolo
[FONT=Times New Roman, serif][FONT=Verdana, sans-serif]I think there may be a problem surfacing with one of the components in the CR tdi emissions system. (At least it surfaced on my 2009 tdi !!)
[/FONT]
[FONT=Verdana, sans-serif] [/FONT]
[FONT=Verdana, sans-serif]On 2/13/10, the CEL came on after fueling up my 09 tdi. It stayed on the rest of the week until I took it in the following Friday (2/19) for a state inspection. The repair shop that I take the car to for servicing found the following code: “P048C – Sensor for Exhaust Flap”.[/FONT]
[FONT=Verdana, sans-serif](The reason the car is at a repair shop and not the dealer, is that the car had just turned 40,000 miles. The dealer didn’t instill confidence in me after they overfilled the crankcase in 2 of the 3 free oil changes – but I digress. I have been using this repair shop since the mid-90’s on a 1990 diesel Jetta and 2003 Passat.) [/FONT]
[FONT=Verdana, sans-serif]The owner at the repair shop suggested that I bring this up with the dealer and see if they would perform a good faith repair since it is emissions related and only 4,000 miles out of warrantee. I brought the car to the dealer and they indicated that I will need to take it up directly with VW. I also found out that the sensor is $89, the exhaust flap is $410, and the flap is back-ordered. I thanked them for the information and set up an appointment at the repair shop to have the fault code addressed and have the DSG transmission serviced.[/FONT]
[FONT=Verdana, sans-serif]The repair was performed on 3/1. The exhaust flap has an electric motor that opens and closes a flap inside the exhaust pipe. They suspect it’s function is to speed the heating of the cats that precede it. They found that the flap was bound up. It had a lot of soot built up that stopped the flap from opening and closing. Instead of replacing it, they were able to clean it. They tested it after and the flap operated fine. They also mentioned that removing the exhaust flap was not difficult.[/FONT]
[FONT=Verdana, sans-serif]I inquired if it was soot or corrosion that bound up the flap and it was definitely not corrosion. But soot from where?? The only thought I have at this time is that it is residue from the regen cycle collecting on the flap. We have no idea how long the fix will last – 400, 4000, or 40,000 miles. [/FONT]
[FONT=Verdana, sans-serif]I can’t see the exhaust flap itself being the problem; instead it looks like something from upstream is collecting at this component. There were no other codes thrown so the rest of the emissions system is probably within spec. Is this problem a function of the emissions system design? [/FONT]
[FONT=Verdana, sans-serif]Several people have seen this already and given the fact that the part is back-ordered, leads me to believe that this problem may be systemic in nature. [/FONT]
[FONT=Verdana, sans-serif]When the code was thrown I didn’t notice any loss in power or drop in fuel economy. Some of the specifics for the my tdi are it is driven mostly at highway speeds, located in NH, I do use the Power Service additive (white bottle) with every fill-up, and oil changes every 10K. (I did check with the service rep to make sure that 507 oil was used during the free oil changes, and supposedly it was. If they used the 505 oil instead, maybe the higher ash content caused this – more ash, more regen cycles, more soot?)[/FONT]
[FONT=Verdana, sans-serif]When/if the problem surfaces again, I’ll try to get some pictures of the flap – but hopefully I won’t see it again for a while. [/FONT]
[FONT=Verdana, sans-serif]BTW, parts and labor for the DSG service and repair of the exhaust flap came to $400. If the dealer performed the exhaust flap “repair”, I figured it would have cost me ~$500 for parts and labor. The DSG service would have been on top of that – ouch![/FONT]
[FONT=Verdana, sans-serif]I’ll keep everyone posted if I learn anything else or if the CEL comes on again for this issue (it has been fine over the last 2 days).
I just wanted to pass this along in case others see this code and are wondering what is going on.
Regards,
Marty
[/FONT]
[/FONT]
[/FONT]
Regards,
Marty
[/FONT]
[/FONT]
