Just make sure that you don't get air into the ABS portion, if you do the regular service portion is fine up until the ABS activates then the service portion will have air in it and the pedal will go away rather surprisingly I've heard! Before you deliver the car, it might make sense just to get the ABS system to activate and verify that the air is out of the system entirely.
It sounds like you were able to work through the ABS procedure though?
