Drizzten
My '02 Golf GL 5-speed (~66,500k miles) was doing fine this weekend until Saturday night.
I was driving home after spending some time at a friend's house. I started normally and drove to the street's stop sign without leaving first gear. Angry with something unrelated to the car, I took off under hard acceleration (+4,000 RPM as I prepared to change gears) from the sign. I found it was surprisingly hard to shift from first into second. And then hard to shift from second into third, and then third to fourth and fourth to fifth. Shifting into reverse isn't a problem.
When I say hard, I mean it feels like I'm putting more than 15 pounds of pressure into the shift, often with an abrupt gritty changeover from neutral into gear. Shifting out of gear isn't much easier. On the drive to work this morning, the time it took to force the car into the gears was long enough to drop a few MPH and slow traffic down behind me a bit.
I tried doing a search but didn't come up with anything over the last month. I vaguely recall seeing something like this in the past and some discussion revolved around getting the transmission fluid changed. I've had my regular maintenance at the dealer since I got the car new and haven't had any issues with them...but if there's a cheap fix to this that doesn't involve hours of overpriced labor, I'll gladly take it.
Could the sudden high engine speed affect the tranny somehow? The car drove normally all day up to that point. No leaks were detected under the body when I got home. Everything else seems fine.
The car's almost bone stock: no major mods at all. Only a VAG-COM IQ adjustment a few months ago to lessen gunk build-up in the intake.
Help very much appreciated!
