suger
question is I have both a 2001 golf tdi and a new auto 2013 passat. With the 2001 I used to shift in the 2 to 3 k range on the rpm and keep it above 1800rpm for I had heard about issues with running in a low rpm i.e. intake manifold coking/ clogging and such. I noticed on the 2013 auto that the shift points are preferenced to keep the rpm as low as possible, normally I will see it run at 1000 to 1200 rpm. I know that there is a lot of newer technology out there with this engine but just wanted to ask the quesiton of weather or not this could be a possibility with this engine due to the shift points
