Over the last week, I've on 3 occassions, found the engine unresponsive to starting. The car is a 2013 TDI SEL. I push the start button as per normal and get some lights on the dash, glow plug, engine, no error. Once was messaged to "put car in P" and on another occassion was told to depress the brake,BTW, Both times the shifter was in the appropriate position and the brake was depressed as one would normally do. Anyway, no engine cranking and after multiple fiddling with the brake, shifter, and several pushes on the start button the engine has started and peformed completely normal.
Called the dealer today, explained the situation, pretty much got a "we can look at it, but without an error msg code thrown, pretty hard to duplicate. So, I"ve decided to continue on and see if it ultimately breaks down or heals itself.
Anyone experienced a similar situation?
TIA
TIA
