Ritzar12
My car went from running fine; to sputtering and running fitfully; to starting at all only after extended cranking; to no starting at all. All of which began after backing over the curb on the way out of the driveway.
I have read the OBD codes and fixed those problems and I have gone through every troubleshooting guide I can locate. Fuel is available at the tank and through the filter. The glow plugs get wet, so I think I am getting fuel to the cylinders. I have an electronic copy of the Bently manual but it hasn't proven to be of much use to me.
The timing belt in overdue for changing. I do not have the tools, facilities, or expertise at this time to replace it myself and the closest 'trusted' TDI mechanic is in San Antonio - 2.5 hours away.
How do I determine what the problem is and how to go about getting it fixed.
I am not adverse to learning how to do this myself. I just need some clear way to determine what needs to be fixed.
