Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > South Eastern USA
South Eastern USA Local discussions for those in the South Eastern USA. (Alabama, Florida, Kentucky, Georgia, Mississippi, North Carolina, South Carolina, Tennessee)
Old July 14th, 2015, 01:25   #1
aracoma1
Default Blend door repair
Does anybody recommend a good mechanic to fix my blend door on my 2004 Jetta TDI in the Alabama or Atlanta area? My vents have been spitting out tons of foam, and have a feeling I won't have heat this winter.
aracoma1 is offline   Reply With Quote
Old July 14th, 2015, 08:31   #2
SilverDieselDemon
SilverDieselDemon's Avatar
Fuel Economy: 41 MPG low 60 MPG highest.
PM Richard55 he's 35 mins East of Atlanta
2003 2D TDI Golf 5M 320k Indigo Blue
2003 Beetle AutoBox 149k
1987 300DT Mercedes 3.0 240k
Atlanta TDI Mafia Member
SilverDieselDemon is offline   Reply With Quote
Old July 14th, 2015, 08:39   #3
fabed23
Richard55. Highly recommended.
I just got done with that job and boy is it nice! It only took me forever to finish though!
fabed23 is offline   Reply With Quote
Old July 14th, 2015, 14:05   #4
aracoma1
I have taken out my center console for cleaning, and removed the glove box. The DIY seems to make it seem like I simply take out the radio, and carefully push the controls out of the bottom. Then I will have access to the heater box and the blend door inside? My worry is if the heater box can be opened without breaking it, and if I would have enough access not taking out the dash. I feel many mechanics would rather try to sell me a heater core job with a new heater box rather than fix it with tape
Old July 14th, 2015, 21:44   #5
vwjettadsl
vwjettadsl's Avatar
You're not going to be able to a good through job without removing the entire dash and HVAC unit. That's how I always do it anyway. It's a $350 job, that will give you something to compare to at least.
If you plan on doing it yourself allow a whole day to do the work, best if you have a helper, goes faster.
Cheers,
Ben
Trusted TDI Mechanic
Mobile Timing Belt Replacement, I travel to you
Malone Tuning Dealer, I offer mobile tuning service for ALL TDI's
www.vwtdisales.com
vwjettadsl is offline   Reply With Quote
Old July 15th, 2015, 07:38   #6
d2305
Hutchinson in Birmingham is worth a call.
d2305 is offline   Reply With Quote
Old July 18th, 2015, 07:29   #7
DanG144
$350 is a very decent price for this job. I have helped one guy do the job, and not being pros, it took us 11 hours or so.
If I can find someone to do mine (like Richard 55, who I heartily endorse) then I would pay them.
Has anyone seen a link or thread on creating a hole in the HVAC box to do the job? I seem to remember a reference to that recently. In fact I have an HVAC box out of a wreck thrown under the shed to practice on, in case I wanted to do just that.
It seems to me that there are in fact 3 doors that need to be re-covered, not just one.
Old July 18th, 2015, 08:10   #8
DanG144
New Beetle hack repair video:
https://www.youtube.com/watch?v=2UswcVaEsME
New Beetle optional access to temperature control door (only one of the 3).
http://newbeetle.org/forums/new-memb...dash-assy.html
I must say that the repair that TerryTDI did on his doors (that I helped with) was a much higher quality repair, and we did all 3 doors. One that selects between recirc and outside air. One that blends or selects temperature, and one that selects exit paths. But it took a long time for us to do. This was on a Mk IV Jetta. Since Terry is by nature meticulous and careful, he did not break any tabs or plastic parts.
I know that Richard55 has done this job on one or two MkIV New Beetles, and last I knew, he was not eager to do anymore.
Old July 27th, 2015, 08:26   #9
jimbote
jimbote's Avatar
just did the "shortcut" blend door repair yesterday on a jetta ... took just under 3 hours ... i disagree that you can't do a good job with the dash in place ... i used hvac foil tape and it turned out great.... the alternative means breaking into the cooling system and the ac system... way too much time/money for such a simple repair
Old July 27th, 2015, 08:30   #10
DanG144
Good to know, Jim. Thanks for speaking up.
This will probably happen to all of us sooner or later.
Dan
Old July 27th, 2015, 09:02   #11
vwjettadsl
vwjettadsl's Avatar
Good to know it can be done, guess I'll investigate it on my next blend door job. Although come to think of it the next job is a heater core replacement, so I'll have to pull the HVAC unit anyway. Oh well, at least I can try to see how you did it while still in the car.
Were you able to do both sides of the doors and remove all the old foam?
Thanks,
Ben
www.vwtdisales.com
Old July 27th, 2015, 09:19   #12
jimbote
jimbote's Avatar
Thanks,
Ben
yeah i was able to get all the old foam off both sides of the blend doors ... it took some time sticking my fingers through the holes and rubbing the old foam and film off.... i used laquer thinner to clean the doors before applying the tape ... i could only access one side of the blend doors to apply the tape but this is sufficient to make the repair ... the car now has cold ac and hot heat ... most difficult part of the job is removing/replacing the front plenum for final blend door access .... take time to study how it is affixed before reinstalling
Old August 6th, 2015, 21:57   #13
fabed23
Just took apart dash and all recently and it was a pain. I like jimbote's method.
It was fun seeing it apart and learning the ins and outs but lets say it was not easy getting back together!
My car was apart for weeks and I was driving with no dash, etc.
Old August 7th, 2015, 18:30   #14
Cha2ga
Cha2ga's Avatar
Fuel Economy: 49city, 53hwy
This is how I did my new beetle. It's been almost a year and is flawless.
Go to post 27
http://newbeetle.org/forums/showthread.php?t=85170
Cha2ga is offline   Reply With Quote
Old August 17th, 2015, 17:43   #15
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Yeah Dan and I consumed a whole day pulling the dash out on my car a couple years ago, unfortunately we had to remove the dash do to a faulty heater core. I think we both said we would never do that again ( however if Dan needed his done and decided to do it I would gladly help ). It was a real PITA! If you can get away with just repairing the door like Jimbote is recommending then that's the way to go.
If somebody would do the job pulling the dash to do it for $350 then that is a real bargain! If you have the dash out might as well swap out the heater core while you're in there.
2K jetta gl tdi 5spd 401k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Blend Door Repair Secret '96 Passat B4V diesel300dmanual VW MKIII-A3/B4 TDIs 107 April 3rd, 2018 22:21
Oh oh...Blend door jammed. A_Shifter VW MKIV-A4 TDIs (VE and PD) 1 June 16th, 2016 23:14
Blend door bushing ??? pricha00 Ontario 1 August 12th, 2014 15:43
Looking for write up or DIY on how to repair the AC blend door on my 2003 Jetta TDI. ericgray1 VW MKIV-A4 TDIs (VE and PD) 0 July 14th, 2013 18:47
heat issue after blend door repair Woodworker VW MKIII-A3/B4 TDIs 3 March 10th, 2013 17:17
Page generated in 0.16672 seconds with 11 queries
[Output: 128.66 Kb. compressed to 107.61 Kb. by saving 21.04 Kb. (16.36%)]
