Old June 23rd, 2005, 15:22   #1
Ynot
Fuel Economy: 45/42/38
Default 2 & 3 bar maps
Is there an advantage of using a 3 bar map even if you do not plan on boosting over 20? Would the 3 bar be more linear since you would be controlling more in the middle of it's scale rather than the upper end of the 2 bar map.
Ynot
Ynot is offline   Reply With Quote
Old June 24th, 2005, 03:30   #2
Aligator
Default Re: 2 & 3 bar maps
no, there is no advantage of using 3 bar map if you don't go over 1.5bar boost.
if you want to use it and have good boost contoll you need to get your ecu reprogrammed.
Aligator is offline   Reply With Quote
Old June 24th, 2005, 07:10   #3
KI4HOK
The only thing that the 3bar map should (I'm still expermenting) do is dupe the computer into giving you about 4-5 pounds more boost. I'm still looking into it, will post results.
By the 3bar map is available at the dealer, its used on the Tourag. $56.05 @ Suncoast Motersports.
KI4HOK is offline   Reply With Quote
Old June 24th, 2005, 07:27   #4
Aligator
3bar map will give more boost for sure but it will also make car boost more during part load which is not good.
Old June 24th, 2005, 12:04   #5
Ynot
Thanks Aligator!
Ynot
Old June 24th, 2005, 14:38   #6
KI4HOK
Why is more boost during part load bad?? I can understand if you are in a surge area, or something like that, but I thought more boost would be better expecally if you have smoke issues.
Sorry if this is a boneheaded question.
Old June 25th, 2005, 01:38   #7
Aligator
Boost doesn't come out of nowhere. Boost comes from exhaust gas dynamics so if you want to have more boost more energy has to be put on turbine to spin it faster -> therefore higher EMP -> higher load to the engine -> efficiency is worse -> worse mileage.
So at part load it is the best to run on as low boost as possible but high enough to let all fuel burn well.
Old June 25th, 2005, 06:14   #8
03_01_TDI
Banned
TDI(s): Na
I wonder how much boost at 70mph on cruise would the 3bar map increase the PSI? I've played with IQ settings and can get from 4-10psi - thats a huge range!
This could be a means of fixing a car that smokes other than playing with the IQ. which effect boost as well
03_01_TDI is offline   Reply With Quote
Old June 25th, 2005, 07:56   #9
Aligator
It will add up to about 20% more boost, but IMO this not the way, especially if you run RC4 - it will kill you turbo very fast because you'll run about 2 bar boost (29 psi) at WOT on a 3bar map.
The proper way is to get 3bar map and get the ecu reprogrammed to work with 3bar map.
Page generated in 0.13047 seconds with 10 queries
[Output: 82.97 Kb. compressed to 70.56 Kb. by saving 12.40 Kb. (14.95%)]
