Jheddai-nite
Hi, I am trying to fix an issue that seems to be slowing down my TDI. It runs cold and sometimes has trouble accelerating by bogging down. So it can, but not always feel like it is missing. Sometimes cant climb hills just have to go slow. I think the thermostat is either stuck open of it is the wrong one (guessing 160 degrees) Also guessing it needs a 190 degrees to run at full capacity. Already tried cleaning the EGR valve, draining the water from the fuel filter, and primed the fuel lines from air. I learned the hard way which additives not to add to the tank. Also tried spraying cleaner solvents/water into the air duct to flush out the carbons. All this worked great but still having a bogged down sensation when stepping on the gas sometimes. Any ideas?
