maebee1
For the last two mornings I've had to start in near zero degrees(F) temperatures. Both days the engine started right up however the coolant temperature warning light came on within the first minute. I turned the engine off and restarted it with the same result. When I let the car sit for 10-15 minutes and tried starting again she fired right up and the warning light did not come on.
I attribute this to the cold temperatures but is it something I should be concerned about? Is there something I should be checking?
Thanks for the help.
