Chris NF
Hi All,
Jetta 2004 TDI PD
I had an oil light 2 days ago. I stopped and checked, it was low. I topped it up again and went on. Just as i got home yesterday it was on again. I changed the oil. Knowing that I put in the right amount of oil I was suprised to see the oil light come on again.
The car as never used oil, the spare can in the trunk was there for years and i check everything regularly. The filter was replaced and i'm going to check to be sure its in right and double check the part #.
If I start the car and wait to see the oil light I can turn it off and check the level. With the dip stick, It is low but soon builds back up to the full line. So i don't think the oil pump filter screen could be blocked. It seems there must be trouble with the pump or some blockage else where thats causing oil not to return to the pan.
I've got to drive back across the island today so i'm fingers crossed that its the oil filter. But i'm dam sure I put on right and that wouldn't explain the oil light before the oil change.
If you have any experence with this please let me know how you fixed it.
Chris
PS: I use an oil extractor, could i have hit something with the hose?
Jetta 2004 TDI PD
Chris
