50harleyrider
- Joined
- Jun 16, 2007
- Location
- charleston,wv
- TDI
- 2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
My Passat has been lurching and sometimes quitting lately and I've noticed the clear supply line to the injector pump from the fuel tank is not full when it's running-almost looks like air in it but most likely a weak stream. Is that normal for a 96 and what pressure should the supply pump be delivering at the injector pump? Is there a port on the injector pump that I can check supply pressure? Filter is new.
