2GreenTdi's
- Joined
- May 28, 2001
- Location
- Sootland
Well the thread from the post mortem of Steve's motor has been locked. I don't know if it was for the direction it was heading or if people just want it buried and to forget the troubles that it's life and death caused.
I don't know if Steve has an interest in having the issue put to rest or maybe has just succumbed to the pressures from the masses.
I myself am ready to accept the turbo boost theory. DB makes that case very clear and there is no doubt in my mind that a situation as he described in the previous topic had occurred.
I wonder though, how much the likelihood of a defective engine casting may have had on the failure. IMO this is what contributed to the catastrophic destruction of Steve's motor.
In all probability, Steve gave the motor the push it needed to fail earlier than it would have without any meddling.
I have held the VNT 15 Turbo in my hand and it's hard to believe the connecting rods would fail before it. (Unless VW's swiped trade secrets from Trabbi.)
IMO Some sort of hydraulics problem would much more likely have had an impact on the failure and there was some sloping around going on in Steve's motor (thus the previously seen shavings) and the overboost/burn had an effect on the sleeve dropping, creating failure.
Many were adamant about placing the blame squarely on Steve and were open about his questionable changes being the root. I find them more accurately to be a branch.
Finally, I think a non opinionated metallurgist would be able to tell for sure and it would sure be nice to have one at least take a peek at it. Just for finality.
