lucassayers7
- Joined
- Oct 22, 2017
- Location
- southern NH
- TDI
- MK6 TDI Golf (recall) MK1 Rabbit TD from NA(sold) MK1 Scirocco TDI (Building)1990 Corrado TDI(Daily)
In November it will be a year since I've had this issue, Been working on too many projects to completely focus on this.
so far done to try and remedy it:
-All N75 hose swapped for new 3mm ID hoses
-boost leak test from intake manifold coupling to turbo coupling(holds 35 PSI fine)
-EGR delete
-swapped N75
-ECU hose replaced
Not quite sure what to try next if a new turbo is the answer seems like i get limp mode after being on the highway not affected by in town, will vcds give me a better understanding of the issue? also this is not cause by the oversize front mounted intercooler or big piping? Also it spikes a little boost and then settles around 13 and pulls strong
-EGR delete
-swapped N75
-ECU hose replaced
