I'm sorry if this has been beaten to death so delete if y'all want to, but I'm looking for advice on clutch and flywheel replacement. I have an 03 mk4 alh jetta with 195xxx miles and the stock clutch started slipping. My car is lightly modded and is my daily driver, I put about 60 miles a day, so I am looking for advice on the proper clutch/flywheel combo. My car is kerma tuned, .205 injectors, bw s7 turbo, straight piped, and egr deleted.
With the mods on the car is it safe to just go back with a dmf and stock clutch or should I look into a stage 2 clutch and or a solid mass flywheel. Part of me says if it lasted 195k on oem equipment then it should be fine going with stock, but in reality the mods were all done within the last 15,xxx miles. I'm afraid if I go back with stock it will prematurely wear everything down.
